Caliper Bolt part number- replace during Rotor change
lrk322
Type R 2021
I’m swapping rotors and read on here that the caliper bolts should be replaced as they are a one time use bolt per the service manual. I’ve been trying to identify these bolts for the front and rear calipers but haven’t had any luck. Does anyone happen to know the part numbers? I know this may be overkill, but as they are a cheap part, I figured it would be a good idea. Thanks for any info!
90107-TGH-A00
number 20 here on the chart
11th Gen Honda Civic Caliper Bolt part number- replace during Rotor change 1762204424473-p2
As far as overkill, it is but like you said part is cheap. I will probably replace it every second time it comes out.
lrk322
lrk322
Type R 2021
Thank you for this, I really appreciate it!
