Changing wheel size for winter to 17s.
Erkul
Eric
NJ
2025 Honda Civic Si
I couldn’t find any threads or how I was wording it. I have a pair of Blizzaks from my old Si in 215/45/17. Looking to get steel wheels or beat up Honda wheels and putting these on. Question is do I need I-HDS to change wheel size or a decent OBD tool?
Sporky McGeuschky
Sporky
Central Texas
Hi.
Man, I would love to see this.
I don't know what an "I-HDS" even is. I am pretty sure that you don't need an OBD tool, though.
You will probably just need to recalibrate your tire pressure in your car's dash computer after installing the new wheels and tires. At least that is how it works in the FL5 Type R.
Just guessing.
Post photos after you install your winter setup...
and feel free to post here on the Civic Unslammed thread:
Cheers.
Spart
2025 Integra Type S
Just guessing.
I think OP might be referring to the difference in tire circumference throwing the speedometer/odometer off.
I solved this by getting the right size of tire but he's trying to reuse a set he already has.
Blizzaks don't last very long. I'd just live with the minor speedo error and go bigger with your next set of tires.
A GPS will give real speeds at cruise, if you dont have radar signs in your area to calibrate yourself.
Spart
2025 Integra Type S
With as much as I drive each the winter (maybe a couple thousand miles) I get about five seasons out of a set of winters, and when I retire them it's usually because the compound is getting hard, not because of the tread depth.
Erkul
Erkul
Eric
NJ
2025 Honda Civic Si
I am mainly concerned with any complications that might arise. VSA/TC issues. Wheel speed etc.
Sporky McGeuschky
Sporky
Central Texas
Oh... that. Right.
Uhhh... all I know with my oversized tires is that at "60" MPH... I'm actually going about 64 MPH, so....
Just make a... "mental" note?
EDIT:
Also, "right size tire" is subjective, since most of the time the OEM tire is too short and too skinny for the wheel upon which it is mounted. Just my correct opinion. ;)
Only half joking in the statement above.
If y'all do figure out a proper way to calibrate the speedometer once the "correct" size tires are installed, I would like to know.
Thanks.
Cheers
Spart
2025 Integra Type S
EDIT:
Literally not wrong at all. BMW products are the absolute worst with this.
I remember the joy I felt upon discovering that Bimmercode had the ability to turn off the "speed correction" in my Supra, only to find out afterwards that it simply changed from reading 6mph fast at freeway speeds to reading 3mph fast.
We've had GPS receivers in cars for what, two decades now? It's long past time for cars to read the GPS speed and self-calibrate their speedometers. Mumble mumble there oughta be a law...
Twomblymd30
Madison, WI
2023 honda civic si
I swapped my winter rims (also used on my 9th gen 2012 si) which is a 225/45/R17, 17x7.5 rim I believe offset not sure of off memory... Anyway, no codes or anything. i did do the tpms calibration after swapping. the sidewall height (45) on a 17" tire is almost the same size as the 18" in 35. I am about 1 mph off at 75mph via gps, so close enough for me, and as I said no codes or anything.. hope that helps.
Twomblymd30
Madison, WI
2023 honda civic si
height is about the same on a 215/45R17 as stock 18s. I'm running 225/45R17 mph (gps) is about 1 mph slower than dash, which was the same with the 18s...
Spart
2025 Integra Type S
Yeah my brain was stuck on Type R sizes.
