CTECH Auto Customer Highlight - @getRIGHT
ctechauto
Shawn @getRIGHT drove over 2 hours to come to my shop for a whole bunch of goodies for install. He was very organized, communicative of what he wanted. I was happy to install the following:
- MDR Intercooler
- TSP downpipe
- PTP/TSP downpipe lava blanket
- Dream Automotive turbo heatshield
- Titanium downpipe studs
- RV6 Front Pipe
- Apexi N1 Valved Exhaust
- Spoon lowering springs
- Spoon front and rear subframe rigid collars
- Spoon front lower stiff plate
- Mugen front and rear lateral tie bars
- Wunderladen Racing Rear Motor Mount
Thanks again Shawn, I hope to work with you again!
11th Gen Honda Civic CTECH Auto Customer Highlight - @getRIGHT PXL_20251006_045719585
11th Gen Honda Civic CTECH Auto Customer Highlight - @getRIGHT Oct_2_2025_19_27_41
11th Gen Honda Civic CTECH Auto Customer Highlight - @getRIGHT PXL_20251005_230239298
11th Gen Honda Civic CTECH Auto Customer Highlight - @getRIGHT PXL_20251005_230234236
11th Gen Honda Civic CTECH Auto Customer Highlight - @getRIGHT PXL_20251005_002102208
11th Gen Honda Civic CTECH Auto Customer Highlight - @getRIGHT PXL_20251005_001822842
11th Gen Honda Civic CTECH Auto Customer Highlight - @getRIGHT PXL_20251006_012710253
11th Gen Honda Civic CTECH Auto Customer Highlight - @getRIGHT PXL_20251005_002702487
11th Gen Honda Civic CTECH Auto Customer Highlight - @getRIGHT PXL_20251004_151711802
11th Gen Honda Civic CTECH Auto Customer Highlight - @getRIGHT PXL_20251004_175533589
PNEUMA
Jerry
PNW
2025 FL5
Ha, definitely was a multi-day job! One of the bigger ones that came in from the forum.
Yeah when I saw that list I figured that would be one heckuva long day.
Break any studs off?
ctechauto
ctechauto
Not on this one luckily. But I have a machine shop nearby who built a custom jig/fixture for when I come in with these dumb turbos. That should tell you something. Its always the top right-most stud that has the most common problems because its the only one not exposed on both ends and is built into the turbine housing. Sometimes even hours with kroil and a torch still wont get it without breaking.
TheFactor
Factor
So Cal
2025 CW Civic Type R
Not on this one luckily. But I have a machine shop nearby who built a custom jig/fixture for when I come in with these dumb turbos. That should tell you something. Its always the top right-most stud that has the most common problems because its the only one not exposed on both ends and is built into the turbine housing. Sometimes even hours with kroil and a torch still wont get it.
Good thing you didn’t since there is a few “stud” breakers on this forum just waiting for the snap 😆 as you saw lol.
What area are you in ? For a future reference:)
Mrjustin81
If you were installing an aftermarket turbo and DP at the same time, is it possible to remove the OEM turbo and DP while they are still connected?
ctechauto
ctechauto
Unlikely it would come out easily, if at all. There is an oil drain hose to the oil pan for the return thats buried behind all of it. And also due to the dp length/width bottom angled flange, it likely wouldnt clear the radiator fans and block if you tried to snake it out from the top especially with the turbo attached (which also has to clear the cylinder head studs of the manifold/turbine housing).
If you're trying to save the studs from breaking and trying to sell it, better soak overnight in kroil/pb blaster and just take off the 2 bolts and 2 nuts and leave the 2 studs in the housing. Also taking the nuts off may gall so you have to clean it real good beforehand.
Mrjustin81
Just curious to when the time comes to do that. See if I could save some time not having to duck with those bolts/studs
ctechauto
ctechauto
Nope, you'll likely be fighting it longer than it would be to take it out one thing at a time. And fighting it is infinetely more frustrating than a possibility of breaking a stud, especially if you're already going to replace the turbo anyway.
Mrjustin81
Yeah, thanks. It’s a thought I’ve been having recently Maybe to save some time.
