Dashboard Button / Interior Switches Issues
captain_bboy
Dallas, TX
2025 Civic SI
Hello! I've been working on installing custom ambient lighting in my car, and one of the first things I did was install a toggleable custom dashboard button (like https://www.ebay.com/itm/204149155743). At first I just linked it to the fuse box and had the 12V run through like normal. I ignored the back-light section because I don't want to splice into my car's wiring harness. However, I came back to this project because I really do want the button to be backlit. I added my own spacer connector between the VSA button and the car's wiring to splice into, but when I connected the two, it exposed a problem. Honda inverts the voltage based on dimmability. Meaning they provide 12V through the dimming line when they want no backlighting and 0V when they want full backlighting (12 - provided voltage = light's voltage). Has anyone found a work around for this? I really want my switch to be dimmable, but it being inverted right now obviously was not the goal.
Thank you! (It's a 25 Civic SI)
captain_bboy
Dallas, TX
2025 Civic SI
If anyone was awaiting an update on this, I tried using a lm358p operational amplifier to try to do 12V - the backlighting voltage, but I probably bought cheap parts because the first time it didn't work and the second time it was off by a large factor (12V - 5V was 3V). This is definitely possible with higher quality components, but for now I have just wired it to 12V for full backlighting.
Sporky McGeuschky
Sporky
Central Texas
Hi, sounds interesting. I know absolutely jack squat about cars... and even less about electronics. Wish I could help.
Have you checked with any of the DFW shops on this forum, like maybe
@ctechauto ?
If Ctech can't help, maybe someone there can at least point you in the right direction.
ctechauto
@ctechauto ?
Thanks for the tag, but we try not to touch custom electronic stuff like that. We do have a few recommendations for other shops that specialize in custom electronic mods, including mood/ambient lighting and fiber optic headliners (starry headliners, etc) as they specialize and do that all day long. Feel free to PM me for the recommendations and referrals.
