Downpipe Hondata tune help
Fl5R-23272
Enzo
New jersey
Civic type r
I recently installed a plm downpipe and I’m looking for a way to get rid of the cel (02 sensor/bank1 sensor2.
Looking how to disable this sensor, how to get it done using Hondata or even add it as a mod option nc I’m having trouble
11th Gen Honda Civic Downpipe Hondata tune help IMG_4736
11th Gen Honda Civic Downpipe Hondata tune help IMG_4706
11th Gen Honda Civic Downpipe Hondata tune help IMG_4705
CTRAWR
Honda
Have you tried disabling the P0139 error in the DTC’s section of the misc. area of the calibration window and then uploading the calibration to the ECU?
SKINNIE
DFW TX
ISF, 23' BB FL5
You run into any fitment issues with those PLM parts?
ronthebeast2000
Ronald
New York
Okay so im running the plm catted downpipe as well as you, no front pipe with the dual resonator delete. Same issue the only way to resolve this, from what I heard from a plm rep is by getting a better 02 bonk if not than what I did was exactly what the other user suggested which is completely remove the code from hondata. There is I believe 3-4 codes related to p0131. I just got a proper tune from mikethetuner and he had to make the adjustment for me as well because I still had the code. You didn't break any header bolts when taking out stock dp? And were are to put all 4 back in right? I upgraded mine to the titanium while i had them out.
