Drivers Side Mirror Vibration
frontlinegeek
Jason
New Brunswick, Canada
2020 CRV Touring, 2022 Civic Touring Sedan
So to break in the new car, my wife and I took it on a weekend trip and something I noticed was that the mirror in the drivers side mirror assembly seems to vibrate at highway speed. I can't see any such vibration in the right hand side.
Has anyone else noticed this or can you pay attention the next time you are running at highway speed?
leodan
louisiana
2022 Honda civic touring
I will pay attention but have not noticed. What month was your car assembled?
mondreyt
Edmond
GA
Civic
No vibration here also. Have you tried visiting your dealer?
frontlinegeek
frontlinegeek
Jason
Not yet. I want to go for a couple more drives on known different pavement conditions around me and drive between 90 and 120 KPH to see what is or isn't happening. Just to rule out the possibility of roadway surface having been the issue or not.
Also, it is a super specific problem so there isn't a huge push to get it dealt with right pronto.
Wajahatsajid
Wajahat
Utah
2022 Honda Civic, 2018 Audi A4
Late response, but I had the same issue, got it checked a couple days ago and they replaced the mirror and said it was still shaking. The dealer said that it was most likely a manufacturing error and that it would be covered under warranty.
zeroptzero
Joey
Ontario Canada
I've had that on other vehicles and I don't like it. Move the mirror around and see if it frees up a bit, go full wide and then full in and full up and down and back to your preferred spot. See if it helps any ?
sgtmorph
Long Island, New York
We‘ve seen a few other models come in for the same issue. We are replacing the mirror glass under warranty because in some cases, the adhesive used during manufacturing fails, causing the glass to vibrate away from the plastic base on its own.
So yours will likely continue to vibrate until you bring it to the attention of your local Honda service. You’ll be covered under warranty. And The more errors brought to Hondas attention, the quicker a bulletin is issued to the masses. ??
frontlinegeek
frontlinegeek
Jason
Funny thing is that I noticed that our 2020 CRV has the same really slight vibration at 120kph as well. Never does it in either once you get below about 100.
I definitely understand the adhesive aspect of it all but when I took a trim tool to pop it off and check things, everything was really tight (Did this shortly before posting this original thread).
Not a lot of highway driving lately and it is now the winter and we see -25 C or lower frequently where I live so I will wait for the spring to see how things have held up. Fortunately, I have an excellent overall experience and relationship with my dealership so I am not too worried if I have to put in a warranty claim. But yes, if it is a real thing, I won't delay as it will for sure help a TSB come into existence a lot faster.
