gerryman81
- Joined
- Jun 14, 2024
- Threads
- 0
- Messages
- 40
- Reaction score
- 83
- Location
- Austin, TX
- Vehicle(s)
- 2024 Civic Type R Sonic Grey Pearl
So I didn't do a reset or calibration the first time when I installed the Hyundai spring and that may have been partly why I was having issues. I did install it with the valve closed and from what It looked like with the actuator in the right position though but couldn't get the valve to open when cycling the ignition or when driving.Did you do the reset procedure with the actuator off before you reinstalled with the new spring? Glad your original spring isn't rattling anymore but I had no issues with my install and valve is operating as it should.
When I put the original spring back in I did a few ignition on/off cycles to get the actuator in the right position and then installed the spring on to the valve directly before gently putting the actuator back on top to line everything up. After that it was functioning correctly again.
Curious what your procedure for install and calibration was so I can try that out and maybe put the Hyundai spring back in. One thing I noticed was that the new spring had a lot more resistance and I had to bolt down the actuator a lot tighter so wasn't sure if that tension was keeping the valve from moving correctly.
