FK8 BOV fits FL5?
Shankmeyster
AZ
23 Type R
If you are using the recirc valve version then you should be all good.
Simply_Clean
Atlanta
2017 Civic Type R
I changed out the coupler and I’m running the recirculating kit. I ran it without and got a CEL on my first drive
interesting, I have not gotten a check engine light venting to atmosphere and have driven it over 100miles like that.
Correction on my previous post! The coupler you need is the stock FK8 or a aftermarket if you want stronger 2.75” to 2.5” coupler.
SimplyClean
Atlanta
2023 Boost Blue Civic Type R #647
It was an installation error on my part. Are you still running without the recirculating kit? I'm tempted to do this to hear the sound difference.
encarnacionb
Brian
Tundra, Integra
What coupler did you use? I installed this on my FL5 with recirculating kit Monday. Used the stock coupler and just clamped it down. Seemed like it was on pretty good but might change it out.
So used a 2.75”- 2.5” reducer straight coupler. Stock one will pop off and leave you in limp mode.
2.75” to the throttle body and 2.5” to the pipe.
encarnacionb
Brian
Tundra, Integra
Thanks bro! I’ll order that tonight and swap it out this weekend!
