Vito.FL5
Unfortunatelly, this thread has 28 pages and I don´t think we are going anywhere.
It’s been over 2 years since the FL5 came out and people are still ignoring the real problem.
What’s the point of doing a 3-pass radiator, if all it does is make the system worse?
You guys still don’t get how a cooling system works. I’m not an expert, but just stop for a moment and look at the engine bay.
OK, now that you did that, let’s recap what happens:
Water flows out of the head and splits into:
Now let’s look at the stock radiator: water enters from the top and exits from the bottom. That means all the tubes are available at once, minimal restriction, maximum flow. Fast flow means better “scrubbing action” inside the tubes, which improves heat transfer.
Now let’s say you go and cut the radiator into 3 parts and run them in series.
What happens?
You just tripled the restriction.
Coolant slows down.
Flow gets redirected to all the other paths (heater, turbo, etc.) because they’re now less restrictive than the radiator.
So now less coolant flows through the radiator, and more goes through circuits that add heat (or do nothing)
Sounds like a bad idea yet?
And yeah, maybe your ECT2 sensor reads 20°F cooler now. But that doesn’t mean you’re rejecting more heat. It means water is moving slower, heating up more inside the engine, and cooling down more inside the radiator — but the total heat transfer hasn’t improved, actually, slower flow reduces the radiator’s effectiveness.
There is an old article from NARSA, that shows how a given engine, producing a given amount of heat, and moving coolant at a given speed, will always show the SAME temperature drop between the radiator INLET and OUTLET, regardless of the size, design or efficiency of the radiator. The only thing that changes, is the AVERAGE core temperature. So if you see a big difference between ECT1 and ECT2 (and you believe you are subject to the laws of physics) the only option is that either the amount of heat produced by the engine, or the coolant flow dropped.
Now Instead of messing with how many times water passes through the same core, focus on the actual bottlenecks:
Improve airflow (fan, shroud, ducting)
Increase coolant flow rate trough the radiator (remove unnecessary parallel circuits is one option here, but there are others)
Optimize the radiator face area and core design (louvered fins, proper row count, etc.)
I didn´t get into the stupid headifold issue because this is something we can´t change yet, so I´m focusing in the cooling system here.
- Radiator
- Cabin Heater
- Transmission Cooler
- Turbocharger
- Throttle Body
- Coolant Reservoir
- Engine Oil Cooler (this one goes a slightly different route but whatever)
What happens?
Coolant slows down.
