Payload Limit on FL5 for Long Road Trip
Xmetal
SoCal
CTR, S3
It's so odd that I can't find any payload limit on the DE5? 600 or so pound appeared quite low for a passenger car. That's probably the main reason why the FL5 only got 4 seats? Very odd...For reference, my previously two-seater sports car (Z4M Coupe) have a payload limit of 680lbs! We have 2 more seats in the FL5, but have the same payload limit as a 2-seater???
Cyano_Hibiki
Cyano_Hibiki
Some discussions suggested they calculated the payload limit using an estimate of 170 lbs per person times the number of passengers. So for the FL5 it's 170 * 4 = 680 lbs, and for the Si it's 170 * 5 = 850. Is the DE5 a five-seater? The FL5 having 4 seats is probably not due to what the car can practically load, but more for performance considerations. Also like @TypeRD mentioned, it is likely a suspension limitation than anything else, when under heavy load.
But again, I'm no engineer and my guess is as good as yours.
Edit: fixed typo.
Superhatch
Jacob
Wisconsin
I like the idea of getting a rental too.
Also keeping the car in +R/Sport mode will not be the greatest thing for your parents in the rear, it's a lot harsher back there even in comfort mode.
I've had 3 large adult passengers, plus me & luggage in my CTR for 70+ mile trips back and forth the PHX airport. No problem whatsoever. I normally have the ITS damper module set to comfort.
Note rear tire wear may accelerate due to higher load and increased toe-in from the multi-link suspension, though I haven't noticed any wear. Otherwise, absolutely no problem.
thatonedaveguy
Dave
Texas, USA
24' CW Civic Type R #18788
Pretty sure 1lb = 1lb no matter what it's made of.
The point I am making is you don't need to worry about measuring things if you are putting 4 people in the car, some suitcases, and going on a trip- that is exactly what the car is for.
If you are loading up concrete or other heavy things in large quantities like you might in a pickup truck, it makes sense to measure it out.
Junsupersti
Bay Area
STi
Payload ratings are due to the tires.
Get some extra load tires on 18ā€ wheels and you will be good.
That definitely plays a role, but is an oversimplification of a multi-part equation. You can’t just put extra-load tires on a vehicle and assume it’s all good. The suspension is what’s responsible for dealing with controlling the weight. Have you seen videos of people overloading their pickups?? The tires don’t pop, but the suspension is completely bottomed out. Not safe…especially when the payload (in this case) is mostly people!
The FL5’s Gross Vehicle Weight Rating (GVWR) is 3968 lbs. This can be found on the black sticker in the driver’s side door jamb. This is the maximum safe weight of the vehicle when fully loaded, including the vehicle's weight, fuel, passengers, and cargo. The vehicle’s curb weight is 3188 lbs. This means the max payload is 780 lbs. This really isn’t very much, but should be fine for 95% of the time for most owners.
Superhatch
Jacob
Wisconsin
I think it's quite the opposite. Loading the car above its GVWR to plod across town with some stuff in the trunk, is totally fine in my book (within reason).
Going over the GVWR with 3 more people in the car on a long road trip is worth pausing to consider, which is what OP is doing.
Cyano_Hibiki
Cyano_Hibiki
Thanks y’all for the great discussion! I ended up booking an SUV rental. Talked to everyone that will be on the car and they all agreed a rental is a better idea. Cost will be split too. In the end of the day, I’d rather be safe than sorry. With not a lot of extra cost I get a more comfortable ride and peace of mind.
On the other hand, thanks to you guys now I know a bit more about vehicle weight, suspension, and safety! Proved my point in the original post, this is an awesome place to learn stuff.
SiVinyl
Houston
Interesting. Track enthusiasts say the CTR is a great ā€˜platform’ but not ready to go from dealer lot to track without some mods. Now we hear the CTR isn’t fit to take a family of 4 across state lines. Just enjoy your car (use common sense). However, from experience, no adult will enjoy riding in the backseat of CTR for very long.
There are people of widely varying levels of knowledge and experience on this forum. No one said the FL5 is unfit for the job of lugging a fam of 4 across the country. It’s just that there are nuances that any smart/safe owner should consider, EXACTLY as the OP did!
- Payload (people + stuff)
- Distance
- Weather and road conditions
- Safety
- Comfort
- Familiarity with the trip
- Emergency preparedness (spare tire, AAA, etc.)
Regarding tracking the car : The FL5 is like ~90% track ready, but that comes with considerations too, which are totally normal and expected for a street car. To name just a few :
- Track design and condition
- Weather and ambient temps
- Driver skill
- Tire type and condition
- Brakes and brake fluid type/condition
- Oil weight and age
- Beyond this, most additional considerations will be based on driver skill and the track design.
Even a brand new Porsche 911 GT3 will at least require a tire pressure adjustment before driving off the dealership lot and going straight to the track. LOL!
jpindustrie
JP
2025 SG FL5
Agreed , I always looked at it as a convenient '3rd seat' for when theres more than 2 people riding in the car but its product parameters just leave it with the worst 'road trip' score especially with the size gas tank they stuck us with ;)
