FS - FL5 Camo Vinyl / 2'x2' Sheets / $100 + Shipping
RUNN1N
If anyone is interested in trying their hand at vinyl wrapping in the FL5 camo, I ordered a few extra sheets that'll be ready on Friday--they're $100/sheet ($25/sqft) and each sheet is 2'x2'. Shipping is available, and USPS Priority should be $15-$20. If you need a bigger or smaller sheet, message me and I'll see what I can do.
The vinyl I'm using is an Avery EZRS automotive vinyl with a satin finish--I'm new to wrapping and have taken on some tricky parts, but I'd say it's fairly forgiving stuff. With a little heat, it stretches well, wrinkles and folds come out easily, and I've had no trouble with air bubbles.
Curious to see what some others around here come up with!
11th Gen Honda Civic FS - FL5 Camo Vinyl / 2'x2' Sheets / $100 + Shipping IMG_0771
11th Gen Honda Civic FS - FL5 Camo Vinyl / 2'x2' Sheets / $100 + Shipping Mirror Caps
11th Gen Honda Civic FS - FL5 Camo Vinyl / 2'x2' Sheets / $100 + Shipping IMG_0761
RUNN1N
@machimself - I’ve done all of the cabin lighting (pic above), highly recommend!
HRace
United States
Honda Civic
Thanks for making this available. That center console wrap looks great!
Trey
R-00621
Atlanta, GA
Got mine! Thanks again!!
RUNN1N
Bumping this in case there are '24 owners interested in wrapping something (anything) in camo vinyl--happy to get more printed, feel free to reach out!
mbaapk
Twin Cities
Pacifica
Having visions of wrapping the whole car that way similar to the demos - ?
RUNN1N
I believe they call those visions "delusions". I know because I've had them too. :rofl:
RUNN1N
I've got one more 2'x2' sheet of vinyl on hand--anyone looking to finish the summer with a project?
The vinyl is $100, and shipping within the US using Priority Mail is about $15 in a big triangular tube.
Let me know! :)
arcticdc5
William
Is it too bright inside? How was the install? Have the kits ready to go, just waiting on cooler weather for installation... On the footwell and underseat lighting, do you know which wire codes tap into which as the only instructions I came across were in Japanese?
RUNN1N
It isn't too bright inside, in my opinion, but everything is wired through the speedometer dimmer, so it's adjustable.
Don't install in the heat, but also be careful following the instructions run through Google Translate as the instructions are in Japanese but also LHD-specific. It's better to use the instructions as guideposts but follow a wiring diagram or backpin your harnesses to make sure you're wiring them correctly. If you're counting on a straightforward installation process, these lights aren't that type of project, unfortunately.
RUNN1N
I'm currently out of FL5, but happy to run a few more sheets if anyone is interested--same pricing from above applies! :)
11th Gen Honda Civic FS - FL5 Camo Vinyl / 2'x2' Sheets / $100 + Shipping Camo Vinyl
