Grinding/notchy feeling in my Sport Touring 6MT
KeglerKing
Tony
Earth
2023 Honda Civic Sport Touring Hatchback 6MT
Hey there...
There is a grinding feeling/noise in my 2023 Sport Touring Hatchback 6MT when shifting gears. It seems as if the gears are not meshing/syncing properly. Honda Service Tech said he didn't find anything wrong (of course).
This also occurs when I'm just sitting in my car with the engine not running and I’m just shifting through the gears. Sometimes, I can shift through them all very smoothly, with no resistance; other times, very grindy/notchy. I don't understand it. Any ideas and/or recommendations for solutions?
Thanks!
V3N0M_VZL4
Mauricio
Miami, Florida
2022 Civic SI
I was experiencing the same in my SI but when cooler, I decided to add a bottle of this product to the existing oem oil with 14.5k miles on it, the experience has been very good the Smothness in the transmission after the product is another level, the shifting has been improved, I was a little afraid at the beginning but so far so good.
LIQUI MOLY MoS2 Antifriction for Gears | 50 g | Oil additive | SKU: 2019 https://a.co/d/5hexi0o
KeglerKing
Tony
Earth
I’ll check it out. Thanks. ?
Amm5890
Andrew
2024 CW CIVIC TYPE R - #17038
Hey man, Is this stuff still working well for you? what things did you notice after adding? Was 1-2 a bit smoother?
V3N0M_VZL4
Mauricio
Miami, Florida
2022 Civic SI
I ended up doing the transmission oil change at 20k with redline MTL but the product was working as expected, the OIL tech says that apparently I had a water in the transmission that apparently was causing that issue, not sure if it was condensation, accumulated moisture or if i just passed through a puddle with water ?, I live in South Florida and the humidity here is insane.
