HELP*** weird fluid leak from axle shaft bearing
gakhar
BC
2008 Civic Si, 2025 Civic Type R
Those leak all the time. it's your car so if you want to tackle that make sure you use the copper hammer the ends won't get damage
I mean I'll take advantage of the warranty if I have to, but just going to see if it's reoccurring before I run to the dealership. More just seeing if anyone with the exact same drip had a follow up. If I never see any other liquid I'll leave it be :)
gerryman81
Austin, TX
2024 Civic Type R Sonic Grey Pearl
Noticed the same spot of oil on my car when I was under there a couple of months ago as well. I plan on taking another look and seeing if the leak is still there soon. Didn't look like a lot of oil so figured it was just a very small leak.
