HELP*** weird fluid leak from axle shaft bearing
gakhar
BC
2008 Civic Si, 2025 Civic Type R
Those leak all the time. it's your car so if you want to tackle that make sure you use the copper hammer the ends won't get damage
I mean I'll take advantage of the warranty if I have to, but just going to see if it's reoccurring before I run to the dealership. More just seeing if anyone with the exact same drip had a follow up. If I never see any other liquid I'll leave it be :)
gerryman81
Austin, TX
2024 Civic Type R Sonic Grey Pearl
Noticed the same spot of oil on my car when I was under there a couple of months ago as well. I plan on taking another look and seeing if the leak is still there soon. Didn't look like a lot of oil so figured it was just a very small leak.
ScrimgeourKnives
M
Charlotte,NC
2002 Maxima Se, 2026 Type R
Interesting. I did my first oil change yesterday on my 2026 Type R. 1236 miles. Had the exact same drop in the same spot. I did not have any on the bottom inside of my pan that I could notice. I’m almost positive that it is something from the factory such as assembly lube or what not. I am the exact same as some others on here as in I do not want to take my car to the dealer unless I absolutely have to. I have never let anyone change oil in any of my cars ever.
Absolutely love the car
gakhar
BC
Mine ended up being related to my oil pan. It started seeping and covering stuff close to it. Dealer resealed my oil pan and I haven’t had an issue since.
