Hidden auto door lock via button sequence?
aqf23
Alvaro
Basque Country, Spain
FL5 CW
Hi all,
I’m trying to understand whether the Civic XI / FL5 still supports any kind of hidden BCM configuration via physical button sequences, like older Hondas did.
My EU-spec FL5 does not have automatic door locking while driving (the option does not exist in the car settings. Neither the non-adaptative cruise control), and this seems to be region-dependent rather than a hardware limitation. It’s a feature I personally value a lot, especially coming from other cars that had it.
What also bothers me is that when I manually lock the car and then open the driver’s door, the other doors remain locked. It feels unintuitive to me.
I’ve seen aftermarket CAN modules (AliExpress) that enable auto-lock and some other related functions, but I’m hesitant to install anything that interferes with the CAN bus unless there’s no cleaner alternative. There are mixed reports: one user claims it enabled features not present in the car, while another reports battery drain and odd behavior, so it doesn’t sound very promising.
That’s why I’m wondering: on older Civics (pre-2010 and even later), there were undocumented button sequences using the door lock / window switches to change BCM settings. Since the physical button layout hasn’t changed much, I’m curious whether anyone has tested or confirmed if any of those legacy sequences still work on Civic XI / FL5 — even if they’re disabled or region-locked.
I’m not looking for aftermarket solutions here, just trying to understand what’s still supported internally and what’s truly gone.
Has anyone investigated this on FL5 (any market), or can confirm whether button-based configuration is completely dead on EU-spec cars?
Thank you.
Best regards.
J_D
J
Montreal
The setting in the cluster doesn't exist? Weird
aqf23
aqf23
Alvaro
FL5 CW
Nor the non-adaptative cruise control, cannot change it to manual mode with the steering buttons. It seems to be like that also for the chinese market.
frenzal
Dan
Have you read the owners manual?
On the ITS, you can change the cruise control setting from the steering wheel buttons (well explained in the manual). Don't know about the door lock because I don't want this feature...
aqf23
aqf23
Alvaro
FL5 CW
Yeah, I usually do research before asking things on the forum. The european manual does not explain anything about the non-adaptative cruise control. Already tried every option that I’ve seen in youtube or that ChatGPT has suggested. Dealer confirmed that no european Honda has non-adaptative cruise control, or other options such as the auto-lock.
I have started this post to ask if anybody has tried or knows the driver door button combinations to enable the auto-lock or the all-door-unlock, as civics did in the past.
frenzal
Dan
Just saw your in Europe! Might not have the same options as we have here...
Here to switch cruise control mode, I think you have to hold down the "follow distance" button for 3 seconds. Something like that anyway...
