- Thread starter
- #1
Just confirmed with a Honda Master Technician that what I have written above here is indeed the correct way to bleed the brakes. So I'll be shooting a brand new video to showcase the "factory procedure" for how this is done.PointByPatrol said:
I pulled the video down. Looks like I made a mistake on the proper procedure on the FL5 specifically. I'm hearing that the procedure is to start at the driver front, then passenger front, the passenger rear, then driver rear, then actuate the parking brake 5 times, then re-bleed the rears. I will confirm this when I get back to work. If I was wrong I'll redo the process and shoot a new video. Can anyone else confirm?
Side note: I could be wrong here, but my immediate though on this is that a standard bleeding procedure is not going to introduce air into the system, and can likely be done the "old fashioned way", but in the case of folks replacing their brake lines or calipers (Which inevitably causes air to enter the system), will need to follow the factory process to rid their brake system of air bubbles.
