Scan tool needed to bleed brakes/abs
Ic@ns33urhrt
Southeast
A car
Going to be flushing brake fluid to Endless RF 650. I have read some conflicting information on whether to use scan tool for ABS. Is the scan tool needed? Any info would be appreciated. Any feedback on the Endless brake fluid is also welcome. Thanks.
TDC50
Long Island NY
‘23 Type R, ‘24 GR86
Rhorn
BRZ, Civic Type R
From my understanding you only need the scanner tool when replacing the rear brake pads, and thats only to put the E-brake in maintenance mode
yeaitsahonda
David
Virginia
2023 Boost Blue Type R
The scanner is needed if you want to truly flush all of the fluid out. If you don't use the scanner to do the ABS bleed then the accumulator will still have the old fluid in it. FWIW, I'm a mechanic with a scanner and didn't bother to do the ABS bleed when I switched the fluid. Done a couple of track days and no fade.
Ic@ns33urhrt
Southeast
A car
Thanks.
