Hybrid Racing Shifter Cable Bushings
TR3BLE
Justin
Auckland
Civic Type R (FL5)
One of the mods I’m enjoying quite a lot is the Hybrid Racing shifter cable bushing.
While the battery was out I decided to tackle it and yes while I could have taken the intake off, I felt lazy and I am famed for having small hands so I can work around things with ease ?
This really makes the shifter more stable while the gears are a lot smoother than before, pair with a nice gearbox oil swap and you have a car shifting better than when it was new.
Integra23
2023 Integra 6spd A-Spec
What oil are you using?
TR3BLE
Justin
Auckland
Civic Type R (FL5)
I used Honda MTF III for now.
I do want to try Liquimoly TopTec5200 MTF next time but I’ve got quite a bit of MTF III left so not sure yet.
sfedai0
Maryland
01 civic
I thought that the gearbox was already excellent. Like almost on pair with the S2k.
Midori Garage
Tony
Austin, TX
EG4, AP2, FL5
NGL, the Hybrid install guide turned me off of this upgrade because of how much they said you had to remove. If all you did was remove the battery, then I can deal with that.
Icehawk
2023 CTR #3177 (stolen)
If you need to pull the intake (or it would be easier if you did) - don't be afraid, it's a whopping 4 bolts plus a hose clamp and then it lifts right out. 5 mins tops in or out, I was shocked at how easy it was.
TR3BLE
Justin
Auckland
Civic Type R (FL5)
I think if you remove the intake (remove two bolts and a clamp) then you’ll have way more space to work with.
