Inexpensive Spare Tire Option
2001
Bryan
VA
FL5, 370Z
2005+ Honda Odyssey spare 135/80-17
Very close to the stock tire diameter, 5x120 uses the same lug nuts, will not clear the front brakes but works fine on the rear. Common in junk yards. Around $25 at Pick and Pull.
Went to my local Pick and Pull to find a spare, jack etc. There were around 6 Odysseys there and a couple still had spares. Jacks were rare though. After looking in 45+ Hondas I found one jack that looked OK. Also got a lug wrench from an Odyssey (22mm) and it just clears the stock rim to remove the lugs.
arcticdc5
William
Not bad of an option. I got lucky and scored a never used Acura RL spare and jack kit from a wrecked RL. Best $45 I've ever spent at the pick a part. You have to use a hood prop rod to reach in the backseat opening and flip the switch to get the trunk open though as they are electonic and batteries get pulled at the yard.
Bryan
VA
FL5, 370Z
Originally I was looking for an RL but there were just none locally. Lots of Odysseys though so this option should work for a lot of people.
NoelPR
Somewhere in the SW
24' Integra Type S
Anyway, you should not run a spare tire in the front. The LSD will suffer.
Honda had this warning in the owners manual of their vehicles that came with spare tires and have a Limited Slip Differential.
djl526blue
David
Chatham, MA
This is a great option and I'm going to start looking for my trunk. I was just about to spend $500 for one of those Modern Spares, but this is a much more economical option and certainly "good enough" for the number of times you are likely to use it. From some preliminary looking, I can see the minivan option is more plentiful, but the Acura RL option is a alloy wheel rather than a steel wheel if that matters. Can anyone tell me what year RL spare tires can be used? Thanks in advance.
frenzal
Dan
2024 Integra Type S, 2025 TLX type S, 2004 S2000
Don't forget that with the RL spare, you'll need 5 new lugs for it as it is not the same as the OE type R lugs.
You can check out my thread on the Integra forums...
djl526blue
David
Chatham, MA
I haven't had much luck finding local "pick and pay" salvage yards, but I see a lot of Odyssey spare tires on eBay, many with that great foam donut inside that holds the factory jack and lug wrench, etc. I think I'm going to go that route and then just pick up a storage bag on amazon. I already have the hold down net in my trunk and I'm just going to tuck this assembly into the corner of my trunk. I've done a similar set up for my diesel car that has a DEF tank where my spare tire should be. It does steal some trunk space, but its tied down so it doesn't move around and I like the piece of mind having the spare tire and jack. eBay prices seem to trend below $200 for tire and jack, etc. which is way less than the Modern Spare price of $500 for the Civic Type R. Am I missing anything? If the jack from the Odyssey can lift a minivan, it certainly should be able to lift the Civic. Will I need to buy a new lug wrench?
Bryan
VA
FL5, 370Z
$200 sounds expensive but if it comes with a jack and lug wrench shipped then I guess it's not too bad. Much cheaper if you can find one yourself in a junk yard. I found several Odyssey spares and picked the newest one (tire date). Jacks were rare, I found one kind of rusty Odyssey jack and oiled it up when I got home. I think people pick the cars when they first come in and get the jacks. It did work on my Type-R, I jacked it up with the Odyssey jack, used the Odyssey lug wrench and put the Odyssey spare on and drove it around. Tire pressure warning came on but it worked fine.
I modified the foam under the hatch floor to fit the jack in there. Wrapped up the lug wrench in an old towel and put that under the floor too. I plan on strapping the spare down using the tie downs in the hatch.
djl526blue
David
Chatham, MA
Oh, thanks so much for testing this all for me and the rest of us! Now I can confidently pick up a complete Odyssey spare tire set and know that I can use the jack and lug wrench. $200 all in is still a bargain compared to the Modern Spare option. I'm going for it!
djl526blue
David
Chatham, MA
I Just wanted to report a very good eBay salvage yard in Utica New York called JDP Autoparts. They sold me an unused 2012 date code tire on a Honda Odyssey wheel with the foam insert holding the Jack, lug wrench and jack handle for $170 including shipping. The package arrived in 3 days and was carefully packaged and exactly as shown in the photos. That's a significant discount over the ~$500 Modern Spare price and I'm very satisfied. I'm going to splurge and buy a storage bag on Amazon for $20 and bungie cord it all into the corner of my trunk. This will be my third car without a spare tire using this type of solution and I've found it to work just fine for me. Not as elegant as some of the solutions I've seen in this forum, but effective.
djl526blue
David
Chatham, MA
Hello fellow spare tire fans. I mentioned in an earlier post that I found a fantastic deal ($170 including shipping) on a very clean Odyssey spare tire complete with the foam insert, jack, lug wrench, etc. from a salvage yard that posts on eBay. I store the car on Cape Cod so I just got up here to check out the fitment in the trunk with a heavy vinyl cover I bought for $8 on Amazon. I'm sure those prefer to modify the under cover storage bay in the trunk will find this a crude solution, but this is my third car without a spare and I've found this approach works just fine for me. It fits nicely on the side of the trunk under the cargo net. I was going to bungy cord it more tightly into the corner, but its been in there a week and hasn't moved, so I'm just going to live with it a while. Here's how it looks:
11th Gen Honda Civic Inexpensive Spare Tire Option Spare tire #1
11th Gen Honda Civic Inexpensive Spare Tire Option Spare tire #2
11th Gen Honda Civic Inexpensive Spare Tire Option Spare tire #4
11th Gen Honda Civic Inexpensive Spare Tire Option Spare tire #5
J_D
J
Montreal
What year odyssey?
djl526blue
David
Chatham, MA
2011-2022 fits the FL5. Mine is a 2012 so I will probably be putting a new spare tire on the rim at some point. But the current donut is clean and holding pressure. No dry rot or other degradation so I was going to run with it for a while.
djl526blue
David
Chatham, MA
Hello Bryan,
I was re-reading your post today. So, you can use the OEM lug nuts for the Alloy wheel on the steel wheel donut spare? I was going to buy 5 lug nuts specifically for the spare tire. In my other car with alloy wheels the parts counter guy sold me a different set of lug nuts for the donut. He said that you have use different lug nuts for the thinner steel wheel. Of course, that is a German car with lug bolts vs. lug nuts. Can you confirm that the existing lug nuts fit the steel wheel donut? Thanks.
