Jerking when putting foot off/on throttle only in R mode
simmic9
Sydney, AUstralia
FL5 Type R
Hey guys,
Quick one.
When I'm in R mode and I'm cruising, take my foot off the gas - say, the car in front slows down slightly then goes - and then put my foot back on the gas - the car jerks slightly. Even if I feather the gas it still jerks a bit.
Doesn't do this in comfort mode but only in R mode.
2nd or 3rd gear, anywhere between 2-3.5k rpm. Happen for anyone else/is it normal?
IL
In comfort mode the throttle response is slooooow. The car shouldnā€™t jerk in +R mode, but the throttle response is definitely much more immediate (as it should be). My guess is that youā€™re simply used to comfort mode and need more time to adjust your feet for the ā€œproperā€ modes. Also, in general, keep your RPMs at 2500+ as this is about where the engineā€™s max torque begins. If youā€™re shifting below that (and dropping the clutch), you could be lugging the engine a little and getting some jerking. Lugging is no bueno! These engines like RPMs, unlike ye olde tymey American V8ā€™s.
CaryH
Cary
arbies
Scott
Austin, TX
2023 BB Type-R
Huh... I learned something new. I also experienced the jerking, same as OP. I use Individual mode, but have Engine set to +R. I set Engine to Sport today, and didn't get to drive it much, but it seems to have helped.
IL
Throttle response is the same between sport and +R mode iirc
type r fanatic
AL
'23 Type R - Sonic Gray Pearl
What else does the engine setting change then? I thought it was just throttle response
IL
Iā€™m not entirely sure. I just vaguely recall reading in another thread that throttle response is the same for Sport and +R. Maybe someone else will chime-in. +R engine mode feels more ā€œrowdy,ā€ so thereā€™s gotta be something to that.
