Ktuner calibration settings for novice
BoostedDreams
Heisenburg
South East Florida
2019 Type R, 2006 Mazda 6
Just received my v1.2 for my 18 Si yesterday. I’ve been running the 19.5/23 dual tune and love it!
Have a few questions that i researched and can’t find an exact answer.
I noticed that there are 2 options to disable VSA:
-VSA Traction Control
-UO122 VSA
What is the difference ? Which should be disabled? I just unchecked them both, but don’t see VSA off light on my dash ? Is it off regardless ?
Other than that, I don’t understand “throttle paddling”. I left it on standard. Can this be explained in layman’s terms ? Maybe an example?
Lastly, with the Boost Target Ramp Rate, do most run with it disabled or aggressive 2?
Thanks !
Edit- noticed after disabling UO122 VSA that “drive change mode unavailable” came on aka “sport”. So I unchecked it and it’s working again
KTuner
J.R.
Chandler, Arizona
www.KTuner.com
2017 Si
-UO122 VSA
Thanks !
VSA disable should reduce intervention by the VSA module. U0122 also disable the CAN bus error, but will then disable the sport mode button functionality as well.
Throttle padding is the padding for off/on throttle transition, used for rev hang disable.
BoostedDreams
BoostedDreams
Heisenburg
South East Florida
So if i disabled VSA in ktuner, it’s disabled in the car without me having to push the button and get the light on ?
If drag racing the car, is boost ramp rate disabled the most aggressive setting?
Thanks
davemarco
2019 Civic Type R (CBP), 2013 Audi TTRS
Is the VSA disable checkbox in the KTuner software equivalent to pressing the button, or is it like doing the full disable via the pedal dance?
BoostedDreams
BoostedDreams
Heisenburg
South East Florida
Wish I knew. What’s this pedal dance you speak of?
BoostedDreams
BoostedDreams
Heisenburg
South East Florida
It's a sequence of pedal and buttom presses required to fully disable VSA, and it does not persist once the car is shut off.
Wow. Is there a link to this? What if we just unchecked VSA in ktuner settings ?
