Loose subframe bolts help
Potato fl5
Conner
Socal
Honda fl5
11th Gen Honda Civic Loose subframe bolts help 1000004186
found these bolts about to fall out any one know how tight there supposed to be found multiple say 45 to 69 so I did 50 for now
Potato fl5
Potato fl5
Conner
Socal
Honda fl5
I'm going to take it to honda tomorrow just because they did the recall and I think a steering rack bolt is also missing
11th Gen Honda Civic Loose subframe bolts help 1000004188
TypehaRd
Damen
San Jose
23 Civic Type R/99 Civic SI
Wow are you serious!
wtf is going on with Honda!?
Potato fl5
Potato fl5
Conner
Socal
Honda fl5
So I guess there is not a bolt that goes there they checked on there type r they had. And they swear they didn't take the subframe down but they used to. But they still re torqued the subframe. Naturally I 100% trust them and I'll be checking tomorrow ?
They updated the process maybe a week after the initial EPS recall repairs started, so unless you had the recall fix at the end of September/beginning of October they probably didn't lower the subframe. Unless you had other modifications done yourself, like Spoon Rigid Collars, its possible that it just wasn't torqued all the way from factory which is surprising, but has happened..
Potato fl5
Potato fl5
Conner
Socal
Honda fl5
I actually got the car early October and they did it then who really knows should be good now at least just cost me a couple hours of time
