Lug nut suggestions for TE37 SL Black Edition III's?
deadlyfishes
Matthew
Los Angeles, CA
matthewpablo.com
Any recommendations for lug nuts for my new TE37 SL's?
Rays Dura-Nut? Red? Black?
Muteki with the Red accent?
Something else? Looking for something around ~$200, need a bit of extra cash for tires haha
11th Gen Honda Civic Lug nut suggestions for TE37 SL Black Edition III's? 441461288_10224587326421982_8372558836231840988_n
11th Gen Honda Civic Lug nut suggestions for TE37 SL Black Edition III's? 436382026_10224587326581986_5441962068332798822_n
11th Gen Honda Civic Lug nut suggestions for TE37 SL Black Edition III's? 53543829853_a359a0a45f_o_510490c2-ac0d-4328-9f9c-09d100d1c812_1024x1024
11th Gen Honda Civic Lug nut suggestions for TE37 SL Black Edition III's? BhY8mJE__90551
jwong333
Jason
FL5 Type R
I use McGard Spline Drive lugs with my TE's
The Rays dura lugs are fine. You can also check out raceseng lug nuts. Would just recommend closed lug nuts unless you plan to use extended studs one day.
415FL5
SF Bay Area
‘23 RR FL5
I went with the Rays FN-II’s. So far I’m satisfied with my purchase. They’re a multipiece construction with different color options for the removable cap and floating washer.
If you don’t mind the extra steps of removing the end caps and the use of a key for each lug nut. It’s a solid product.
I paid under 200 before shipping and tax.
11th Gen Honda Civic Lug nut suggestions for TE37 SL Black Edition III's? IMG_4873
11th Gen Honda Civic Lug nut suggestions for TE37 SL Black Edition III's? IMG_4871
deadlyfishes
deadlyfishes
Matthew
Los Angeles, CA
matthewpablo.com
What do you recommend for extended
If you don’t mind the extra steps of removing the end caps and the use of a key for each lug nut. it’s a solid product.
where are you seeing that price? looks like the best I can find is around ~$330
11th Gen Honda Civic Lug nut suggestions for TE37 SL Black Edition III's? fn-ii-lugnuts prices
I’d say get whatever fits your budget and matches the color scheme you’re aiming for.
I’ve only have had experience with Rays dura lugs, Kics, EVS steel lugs and now Raceseng closed lugs. They are all good. No failures.
realtorhoff
South Florida
2024 SGP FL5
Kics Monolith look amazing!
