Lugging the turbo?
Six Speed Si
Henry
Nor cal
2024 civic si
Ay just acquired my si havn’t driven stick in quite sometime and being that the car is turbo my question is what the lowest rpm I can be at in any given gear more concerned with lower speeds example 2nd gear feels ok between 1500 to 2000rpm but is 1500 to low causing any strain on turbo my question might seem noobish but it’s still a question I’m wondering any recommendations?
HondaFan777
Boost starts at 1800rpm. You’re fine.
Don’t lug the engine use the revs to decrease load on the engine.
DYI01
Dan
MD
The one thing I would try to refrain from doing is low RPM + high load. Low RPM + low load is usually fine, either downshift or bring the RPM up a bit before going full throttle. Low RPM and high load is a recipe for pre-detonation, use premium fuel if you insist on doing it.
Six Speed Si
Six Speed Si
Henry
Nor cal
2024 civic si
Maybe my question insinuates that I’m going full acceleration in high gear while at low rpm but that’s not the question at hand my question is leaning towards low speed low rpm right before engine begins to sputter what’s the sweet spot before it’s to low
I personally like running my car at higher rpms when going slow, if I get close to 2k rpms I usually downshift.
Yeah I agree with @Jester04
Around ~2k RPM’s you should be coming toward a stop, otherwise downshift to keep RPM’s up and the car moving ahead. I’d say anywhere from 2k-3k RPM’s is a good “comfort zone” to ensure you don’t lug the engine, but still get good fuel economy. A lot of what you’re asking simply comes from experience (feel + sound). You’ll pick it back up quickly, just like riding a bicycle.
Yep
Yeah that is what I meant thank you dude! On the type R at least I feel second gear is a little long so I tend to rev 1st to about 3200rpms.
I think the main thing to consider here is the load on the engine. Low RPMs while cruising are no big deal but if you are going to apply a lot of throttle you will want to make sure you downshift into an appropriate gear first.
heavyD
Calgary
2018 F87
Once you are sputtering it's too low. Anything above that is fine and it's just a matter of modulating the throttle accordingly. The turbocharger really isn't part of the equation if you are just at low speeds in 1st or 2nd gear.
Robdog2232
Tyler, TX
2023 Honda Civic Si
I'm no engineer, BUT if you keep the throttle pinned and use the clutch to modulate power, you will NEVER lug the engine/turbo. Probably should start saving for a clutch upgrade if you go this route...
Six Speed Si
Six Speed Si
Henry
Nor cal
2024 civic si
thank you low rpm cruising was my main concern
