PERRIN
- Joined
- Apr 19, 2018
- Threads
- 13
- Messages
- 65
- Reaction score
- 82
- Location
- Hillsboro, Oregon
- Website
- www.perrin.com
- Vehicle(s)
- 2017 Civic Type R
- Thread starter
- #1
The ALTA Catback Exhaust Non-Resonated & Resonated for 10th Gen Civic Type R produces 15+ WHP and an aggressive tone without being overbearing for street use. Made from 304 stainless steel with a brushed finish, this system will look great and last the lifetime of the car, backed by a lifetime warranty.
Click here to order yours today! Free shipping in the continental United States
TRUE CATBACK EXHAUST
The ALTA Catback Exhaust for 10th Gen Civic Type-R is a true catback exhaust. Many competitors catback exhausts do not mate directly to the catalytic converter, but rather, to an easier-to-reach flange located behind the subframe. The ALTA exhaust system replaces the entire exhaust after the catalytic converter for a true 3" catback.
HELMHOLTZ CHAMBER
To combat the natural resonance the engine produces, the ALTA Catback Exhaust for 10th Gen Civic Type-R has a much needed Helmholtz Chamber. This unique and precision engineered feature is what sets our system apart from others, ensuring a sporty tone without the ear-bleeding resonance found on many systems for these cars.
RESONATED VS. NON-RESONATED
The ALTA Catback Exhaust for 10th Gen Civic Type R comes in two flavors: resonated and non-resonated. For a more refined and subdued, yes still sporty tone, street-worthy sound, the resonated version is for you. For a loud-and-out, throaty, and aggressive sound, the non-resonated version is more your style.
5.25" SLASH CUT TIPS
The ALTA Catback Exhaust for 10th Gen Civic Type-R ditches the tri-tip look of the OEM exhaust and goes with a larger twin-tip design to fill the bumper. The over-sized 5.25" slash cut exhaust tips add a purposeful race car look compared to the not-so-functional look of the tri-tip OEM exhaust.
304 STAINLESS STEEL TUBING
ALTA exhaust systems are made entirely of 304 stainless steel. 304SS provides high corrosion resistance and is excellent for heat up to 1800 degrees Fahrenheit. Other manufactures may use cheaper 409 stainless steel which will rust and corrode over time, but the added expense of 304 stainless steel is well worth it for the beautiful, long lasting high brushed finish and durability.
FINISH
This ALTA Exhaust System comes in a brushed stainless steel finish. The exhaust tips sport a more heat-resistant brushed finish compared to the rest of the exhaust system.
CONNECTIONS
The ALTA Catback Exhaust for 10th Gen Civic Type-R uses unique and OEM-like connectors to join each tube together. OEM-type butt connectors are used and have both slip and twist adjustments to aid in aligning the exhaust exactly how you want. These OEM-type connectors do not require gaskets and are designed to be very easily removed and adjusted. The complete exhaust hangs from the bottom of the car with the factory rubber hangers.
Lifetime Warranty!
ALTA Performance warrants to the original purchaser, all ALTA cat-back exhaust systems to be free from defects in material and workmanship. *Some exclusions apply
COMPATIBILITY
2017-2018 Civic Type R Yes
2016-2018 Civic Si No
2016-2018 Civic No
HELMHOLTZ CHAMBER
FINISH
CONNECTIONS
Lifetime Warranty!
COMPATIBILITY
2016-2018 Civic No
