Paragon Track Performance Big Brake Kit 355x32mm - Group Buy (FL5/DE5)
lmtlsauto
LMTLS Auto
shop.lmtlsauto.com
Hi all,
There has been a discussion to possibly bringing a new Group Buy around the Paragon BBK for the FL5/DE5 platform. I have contacted the Paragon team and they are not opposed to the idea even though there was one already held for the FK8 platform.
I am looking for a general idea of how many people might be interested in this setup for their FL5 and can commit to a group buy.
This will be for their 355x32mm BBK so it allows more compatibility for those using 18in rims.
There will be an option for either caliper finishing, we have not decided if we do one or both finish during this group but depending on the want we can go from there.
Official pricing has not been given as Paragon is requesting a list of committed buyers first and general count of interest.
Pre-order/Group Buy Details:
1. Minimum of 5 participants required. 20 slots available on the group buy list
2. $1,000 deposit required.
3. Remaining balance required once group buy has been confirmed.
4. Participant list will be updated on this page daily
Based on the last group buy held by the FK8 community, I can give a general idea of pricing but this is NOT confirmed.
Tier 1: 5+ participants: 25% off MSRP
Tier 2: 10+ participants: 30% off MSRP
Tier 3: 15+ participants: 35% off MSRP
Payment:
  • $1,000 deposit required by the end date, or pay in full ahead of time
  • We will manually create the order for deposit / remaining balance on our website for each participant.
  • All major cards, PayPal/PayPal Credit, and Affirm financing accepted
  • *Deposits are non-refundable.
Participant List:
  1. Djseto
Additional pieces available (with purchase of front brake kit):
  • 305mm x 11mm 2-pc rear rotors (hard anodized)
  • 350mm x 32mm Larger 2-pc rear rotors (hard anodized)
  • Rear brake pads - P2 compound $125
  • Rear brake pads - P3 compound $150
  • Rear brake pads - R5 compound $200
  • Rear brake pads - R7 compound $240
More information around the kit.
Paragon Track Performance Big Brake Kits offer superior braking performance specifically designed for track day enthusiasts, and is a significant upgrade from the OEM Type R setup. Come complete with every component required to upgrade your front brake system. Developed with performance, quality, and longevity in mind, only the finest materials/components were used to ensure the brake kits to perform and last under both street and track conditions.
  • Features Paragon PA015 / PA035 6 piston calipers
  • Fully-floating 2-piece rotors, with 72 directional ventilation vanes for optimal cooling performance. Runs up to 30% cooler than O.E. rotors
  • Hard anodized/ENP nickel plated calipers, and hard anodized rotor hats for increased resistance to wear and discoloration under extreme track conditions
  • Piston sizes optimized for each application. Designed to work flawlessly with OEM ABS and brake master cylinder. Compatible with OEM rear brakes. Minimal change in brake bias.
  • Confidence-inspiring heat resistance during extended sessions. Optimum bite, modulation characteristics, thermal stability, and durability
  • Saves 8.8 lbs of unsprung weight vs. OEM (17-19 models, 355mm kit)
  • Recommended usage: Street / Track
  • Complete pre-assembled axle set
11th Gen Honda Civic Paragon Track Performance Big Brake Kit 355x32mm - Group Buy (FL5/DE5) nt-Big-Brake-Kit-Paragon-PA015-1__48557.1645701380
11th Gen Honda Civic Paragon Track Performance Big Brake Kit 355x32mm - Group Buy (FL5/DE5) p-nickel-plated-brake-caliper-22__38873.1709630337
Includes:
  • One pair of Paragon PA015 / PA035 6 piston calipers (hard anodized/ENP nickel plated) *Only difference between the PA015 and PA035 calipers is the maximum rotor size they can accommodate
  • One pair of Paragon 72 vane fully-floating 2-piece rotor assemblies with hard anodized 6061-T6 aerospace grade aluminum hats, stainless steel bobbins, and anti-rattle clips
  • One set of Paragon P3 "Street/Track" semi-metallic brake pads (manufactured by Winmax Japan, other compounds available at additional cost)
  • One pair of caliper mounting brackets and all necessary hardware
  • One pair of Goodridge DOT approved stainless steel braided brake lines
  • One set of caliper anti rattle clips
  • Detailed installation manual
11th Gen Honda Civic Paragon Track Performance Big Brake Kit 355x32mm - Group Buy (FL5/DE5) -big-brake-kit-front-enp-caliper__52278.1723538565
Rexpelagi
John
Nashville, TN
www.youtube.com
I've seen the Alcon kit branded as "Paragon Alcon", so I assume there was some partnership with the development of that kit, but it looks like this is something different? How does this Paragon kit compare with that Paragon/Alcon kit?
Djseto
Alcon is a monoblock design. When I emailed Paragon, they said they make their caliper in their manufacturing facilities. It is not a rebranded Alcon, AP, etc...
