PRL adjustable knob, Acuity base bushings and overland design boot installed.
Snmtazz70
Type R
Installed a few days ago. Not very hard, just one of the shifter base screws is hard to get but just remove a few screws in the console to get to it.
No need to remove the whole center console.
11th Gen Honda Civic PRL adjustable knob, Acuity base bushings and overland design boot installed. 20240110_185035
mbaapk
Twin Cities
Pacifica
Nice! Any change in feel with the bushings? Thinking of base and cable bushings w new detent spring.
Imped
Indianapolis
MK7.5 Golf R, ND2 Miata
Base bushings are practically invisible. Cable end bushings are where you'll feel some improvement.
Snmtazz70
Snmtazz70
Type R
Slight more stiffness in shifts. The stock bushings have a rubber base, acuity's are metal.
Imped
Indianapolis
Yes, I have them. Given the loads the base bushings see, if you can truly feel the aluminum bushings then you've got an incredibly sensitive butt dyno.
GIChoe
Thomas
NorCal
2024 Civic Si
Are you using the stock shift boot collar?
Snmtazz70
Snmtazz70
Type R
No, using the collar from the PRL knob.
