PRL RMM heavy vibration with AC
RickyJeezus
Jack
Los Angeles, CA
2021 Civic Type R
Right? The second they fire up the car, they'll know lol.
I'm hoping the Hasport 62A doesn't rattle too crazy. Went with that over the PRL even though I knew the PRL isn't as stiff. Hasport was great on my FK8.
You guys give the dealers too much credit...you really think they're gonna put your car up on a lift to inspect a couple interior rattles? ?
2025 FL5 Civic Type R
Actually they do, or at least mine has. I even went on the test drive with him driving so I can point it out.
Bsnyder6
Bsnyder6
Virginia
2023 Civic Type R, 2005 Wrangler
Probably could have taken it to the dealer and have them sort out the rattles. (They don't need to know that you have an aftermarket RMM installed)
That might be the next step. All the sound deadening I did hardly made a difference if any at all
RickyJeezus
Jack
Los Angeles, CA
2021 Civic Type R
All the dealer would do is throw foam tape at it, possible uninstall and reinstall interior panels...if that's what you did then there's probably no benefit to taking it to the dealer.
Bsnyder6
Bsnyder6
Virginia
Yeah that's all I did. The whole hatch door seems to vibrate. Even the wing is going bonkers. Only with the AC on. I've just been sweating it out instead of dealing with the vibration
Bsnyder6
Bsnyder6
Virginia
lol, that's why removed mine. and yet, i'm thinking i'm going to reinstall it because the car drives so bad with the OEM mount.
Ended up removing mine too. I'm not sure why the vibration on my car is so horrific but the whole rear end visibly vibrates. hatch door, wing, tailpipes all rattling like crazy. Sucks too because the drive was significantly better with it...Just figure all that vibration cannot be healthy for the car lol
Bsnyder6
Bsnyder6
Virginia
Dealer just blammed my aftermarket exhaust without really touching the car (it sure as shit isnt the cause i've had it for a year and it's buttoned up tight)
cryptolime
Wilmington, NC
i got a CTR RMM and yellow powerflex inserts. just debating whether to install the plain CTR mount or install them with the Powerfflex inserts... kinda tired of installing and removing RMMs, lol
Bsnyder6
Bsnyder6
Virginia
Hmm those look interesting I might give that a shot as well. If you do end up installing them let me know how it goes.
cryptolime
Wilmington, NC
couldn't find much feedback on them but i read someone say there were no extra vibrations with A/C like the PRL/27WON mounts
RickyJeezus
Jack
Los Angeles, CA
2021 Civic Type R
Welp, if i'd had known that you also had an aftermarket exhaust that would've been an easy suggestion to swap it out for the stock one before you try to warranty a rattle....
cryptolime
Wilmington, NC
