Seatbelt Retractor Trim Removal
Gary Lively
Gary
Clearwater, FL
The seat belt allows my body to go forward under heavy braking on the track making steering difficult. I am trying to put on a device that holds the seatbelt from reeling out.
So, I am trying to remove the seatbelt retractor cover panel between the front and rear windows. I removed the access button at the top of the panel and pulled the white button underneath it out a bit which allowed me to get my fingers under the panel at the top. I pulled a bit more than gently and I can see a trim rivet which will not it come out. I am afraid to pull to hard and break or distort the plastic cover panel. Suggestions appreciated!
Gary Lively
Gary
Clearwater, FL
Found it! The white button is a trim rivet's center section and the expanding rivet is not fully released by pulling it back. I was able to get a screwdriver from the side of the panel under the rivet and pry it out. Bad design with a very non-standard rivet.
Its a one time use clip, you're supposed to push it in to release it.
I have several clips on hand to replace any broken clips, including a couple extras of this one too.
Part number: 91561-TVA-A01
Gary Lively
Gary
Clearwater, FL
Thanks for the info! I was able to reset the rivet for the reinstallation. I will visit my dealer for a replacement just in case.
I am still baffled about how to properly remove it though. Brute force with a screwdriver blade doesn't seem to be the best alternative. Hints welcome!
