Vhern
Cristhian
Miami, Florida
2022 Honda Civic Hatchback EX-L RED
Hello guys!
I just wanted to share a little mod I did to the tail lights. It's super cheap— you only need a couple of diodes and some T-wire connectors.
What I did was connect the brake lights to the tail lights, so when I brake, all the rear lights turn on.
But... will this make the brake lights stay on all the time at night? No, of course not, that's why I used rectifier diodes, so the current only flows from the brake lights to the tail lights, not the other way around.
It's a very simple mod, and I know it's not for everyone, but I like it. I haven't seen anyone else do the same thing (not saying I'm the only one who did it, though).
Please note: If you decide to replicate this mod, do so at your own risk. Be sure to disconnect the battery and exercise caution throughout the process.
I crimped two of the T-wire connectors to each diode and marked the diode direction:
11th Gen Honda Civic Simple Tail and Brake Lights Modification with Diodes IMG_6019
Then, I applied some thermal wraps to ensure the conductors don't touch any parts of the car and cause a short:
11th Gen Honda Civic Simple Tail and Brake Lights Modification with Diodes IMG_6020
Connect the diode to the lights: the green wire is for the brake light, and the yellow wire is for the tail light. Make sure to position the diode in the correct orientation so that the current flows only from the green wire to the yellow wire:
11th Gen Honda Civic Simple Tail and Brake Lights Modification with Diodes IMG_6021
And that's pretty much it! Just reconnect the lights, and you're done. Here’s the final result, both with the lights on and off:
getGroyped
Josh
Looks good! Thank you for sharing this. I will be trying this mod :)
YevNi
yev
KCMO - USA
24 Civic HB 6MT, 1250CC Moto
tight
k0to
United States
2022 Civic Hatchback Sport
Weird question, are your map lights/door lights still work? Mine seem to stop working if I step and hold the brake lights for a couple of seconds.
