STFT1 +14% at idle
StockBobby
Bobby
San Diego
2022 Honda Civic SI
FE1
Just flashed my tune and my short term fuel trim is reading +14% at idle. Why does my ecu think im running lean? Is this a vacuum leak?
I have installed prl cold air intake, this is the only mod I can think of that I have installed might be causing this.
Thanks in advance for any help gentleman
StockBobby
Bobby
San Diego
2022 Honda Civic SI
So I did just go back to 91 after running an E blend. But the tune was flashed literally right after filling my tank. Does the ECU keep fuel trim after a new flash?
StockBobby
Bobby
San Diego
2022 Honda Civic SI
update. Couldn't find any vacuum leaks, no loose connections on the intake, pcv appears fine. Am currently sitting around with my battery terminal off to relearn fuel trims. Thanks for the idea @Shankmeyster
Cueyo
Fuel trims usually are worse than expected immediately after a reflash. If you reset the engine adaptation (ie: battery terminal or via scanner), it could help. There's also the chance that when running e85, you destroy your catalytic converter. I ran too much e with a pops and bangs tune on my previous civic and that's what it did. It ran itself rich in my case, so I doubt that's your problem.
ctechauto
Destroying the cat was from your pops and bangs tune, not from E. Ethanol actually lowers EGTs. I know you mentioned yours was from running rich (from the pops and bangs tune), but really talking about the previous sentence.
pwp25si
2025 si
In my non professional opinion, stock trim is very rich, and ive always seen negative ltft before j got a tune.
Have replaced the EVAP purge valve and my trims are fluctuating between ~3% and 10%. Is this normal?
StockBobby
Bobby
San Diego
2022 Honda Civic SI
Im running an OTS tune right now, so not stock fuel trims. I should be at 5% max im pretty sure. I did replace my purge valve and my trims dropped to 10% from 14% which I think indicates there is still a leak. I found that when I press the brake the fuel trim spikes which is leading me to believe a vacuum leak somewhere in my brake booster.
Still investigating.
pwp25si
2025 si
Im on phearable 1.5r and im ltft 0%, k con at .48-.49.
