Tools in trunk. What goes here?
stevie2k
irvine,ca
2023 civic type r (boost blue)
Is this supposed to be a spot for the jack.? But since our cars have a fix a flat kit so it doesn't come with one ?
11th Gen Honda Civic Tools in trunk. What goes here? 20230724_203451
Icehawk
2023 CTR #3177 (stolen)
Yep, you can buy a jack to stick there if you want - the ND Miata has the same type of setup (foam for the tools but just fix-a-flat included) and some folks bought them jacks off ebay so they'd have one. A jack from a "regular" Civic should fit there.
Kinda funny how both cars (R, ND) both include the handle/winder for the not-included jack. Thanks?
Those pieces for the not-included jack are probably removed on the S Grade CTR (for further wt reduction).?
KimzEP3
Kim
Central FL
2022 Si, 1990 CRX HF with a B18 (hubby has 3 CRXs including an SiR)
Looks like wrong shape/size for scissor jack (jack is in the middle in pic).
Spare kit from HondaPartsNow.
11th Gen Honda Civic Tools in trunk. What goes here? spare tire si
AvecVtec
Alessandro
Italy
Civic FL5 Sonic Grey #7155
Spoiler alert! Emergency triangle (EUDM)
11th Gen Honda Civic Tools in trunk. What goes here? IMG_2521
  • Like
Reactions: rui
Dodif
Dodif
Round Rock
How much did this setup run you? I'm assuming it fit perfectly and no modification needed for the trunk tray?
KimzEP3
Kim
Central FL
Correct, fit perfectly as is. Altogether with the kit and tire it was under $300.
Hiro-san
South Africa
Civic Type R (FL5), Civic Type R (FN2)
Hi guys.
Have the same issue. What goes there? I'm also missing the boot foam tray for the emergency triangle. Does it have a part number? Thanks.
11th Gen Honda Civic Tools in trunk. What goes here? PXL_20240509_190728287
11th Gen Honda Civic Tools in trunk. What goes here? PXL_20240509_190805026
