- Joined
- Apr 24, 2018
- Threads
- 47
- Messages
- 956
- Reaction score
- 1,391
- Location
- USA
- Website
- twostepperformance.com
- Vehicle(s)
- 2023 Type R
- Thread starter
- #1
After releasing our DIY Flex Fuel Kit, we have had constant requests for a plug-n-play style kit. We began preparing to do so several weeks ago and have all of the components required on hand, with the exception of the ECT2 plugs. We expect to receive them no later than next week, if not by this Friday. Once those are received, the kits will go into production.
For those that may not know what to expect out of a plug and play kit, installation will require the following:
You will find an immediate and very noticeable increase in performance with either of the Flex Fuel base maps, but like all modifications, to extract the most power a custom tune is recommended. We have partnered with Derek Robinson of IMW to offer custom tunes (at an additional cost) to anyone that is interested.
Pre-order pricing for the TSP Flex Fuel Plug-n-Play Kit will be $424.99. Once we begin normal production, the price will be set to $449.99. Free shipping, as always on orders over $100.
If you'd like to add a custom tune, one can be bundled at the discounted rate of $350. Normal pricing for a custom flex fuel e-tune is $399.
https://twostepperformance.com/collections/all/products/tsp-flex-fuel-plug-n-play-kit-preorder
- Disconnecting the OEM fuel line (above the intake manifold) and replacing it with our modified OEM fuel line with a Flex Fuel Sensor added
- Unplugging a fuse in the engine bay fuse box, and plugging in the add-a-circuit we are providing, which will power the kit. You will be required to cut a small notch into the side of the fuse box to allow the wire to exit.
- The ground for the kit will be just behind the fuse box. You will take advantage of a factory grounding point under a 10mm bolt.
- You will unplug the ECT2 sensor (located on the lower, passenger side of the radiator) and plug in the connector from the Flex Fuel Converter
