SPEC Clutch Proprietary Clutch + Single Mass Flywheel Combos are now available to order!
joshhjackson2112
Josh
Raleigh, North Carolina
18' SI
So far I am planning to go with 2+.
I have an aftermarket DP, CAI, and plan to run TSP Stage 2 Flex fuel.
Should 2+ be fine for this?
I plan to get the Drop in W1 turbo in 2020.
Can 2+ handle the W1 or do I need to go ahead and go with 3+?
I would like to get the 2+ for the street friendly reasons but will get the 3+ if I absolutely need to.
I am about a month away from making this purchase.
(New at Modding)
(New at Modding)
Hi Josh,
2+ will be fine. We are about to install a 2+ with our built engine and GTX2860 Gen II turbo. :thumbsup:
AREA
Chris
Houston, TX
95 hatch Drag car, K20Z3 00 Integra, 07 Civic SI sedan and 18 Civic SI coupe
Happy to report no lockout with revised Spec stage 3 with aluminum flywheel and a fully adjusted pedal. Thanks @Two Step Performance I need tires now... Full boltons on E37 blend and your Stage 2 tune = 28lbs of boost lighting up tires even in third.
Ps: stock clutch line, slave and master. Straight stock setup
Note: I run Amsoil Synchromesh transmission fluid, a 500 gram Circuit hero shift knob and have a 27Won RMM.
AREA
Chris
Houston, TX
10GenPearlSi
Old Man
Bob
Houston, Tx
2018 Pearl Si
No problem man! Just make sure whoever gets this to adjust your pedal at both points!
Did that make the clutch pedal higher than the brake pedal?
AREA
Chris
Houston, TX
AREA
Chris
Houston, TX
AREA
Chris
Houston, TX
I have only heard of lockout in the steel flywheel. Anyone lockout on aluminum? I am on aluminum. I also have a 27Won Rmm and run Amsoil trans fluid
charleswrivers
Charles
Kingsland, GA
'14 Odyssey EX-L '18 Civic SI Sedan '94 300zx twin turbo 2001 Ford F-150 Sport
@Two Step Performance FYI, I think your link on post 1 needs updating. I was trying to get more info and it gives me a 404 on your website.
NekoKinetics
Neko
Chicago
2018 white civic si coupe(SOLD). 370Z Nismo, Mr2 Turbo, 280zx
Looking to pull the trigger on Spec 2+/Steel. Are people still having problems with lockouts?
BoostedDreams
Heisenburg
South East Florida
2019 Type R, 2006 Mazda 6
I chased this problem and spent a good chunk of money trying to get it sorted out. The fix is with the Wilwood master cylinder that spec sells. The downside is the pedal gets quite stiff. I would wait for exedy or get the retro fit. I do NOT recommended spec any longer
