USB C MOD FOR SI
andygump24
jose
2023 civic si
Anyone know the part number for 2025 civic si usb c panel and port. Im looking into converting it into full usb c. Purely for aesthetics.
nawfoo
K
Lost Wages
Integra Si
Honda of Downtown Los Angeles
Los Angeles, CA Ā· (213) 234-2144
Robo7
I’m also interested in doing this. Let me know if you get the part number.
rui
NY & PT
EG6, AP1, FL5, FE1
From dreamshop.honda.com:
HUB UNIT, USB (ILLUMINATION)(C)
Part Number: 8A300-T20-A01
ecaro
Erick
miami
2025 FL5, Pilot Trailsport 2024, Pilot 2017
I wonder what else can we mod from the 2025, would this be a direct fit for the fl5?
Shankmeyster
AZ
23 Type R
Probably the head unit as well with google integration. Would probably wait until a junkyard has one though as the brain isn't cheap.
Robo7
Ok went ahead and tried this part. I figured the part would likely be plug and play but unfortunately it’s not. On pre-2025 models the USB ports are part of the wiring harness. They actually clip into slots in the dash where your USB cable can access them through a hole. There are 2 usb ports and a third connector to power the lights
around the ports.
11th Gen Honda Civic USB C MOD FOR SI IMG_0319
On the 2025 model the USB-C ports are an entirely separate module with 2 ports on the back that are not compatible at all with any of the old connectors.
11th Gen Honda Civic USB C MOD FOR SI IMG_0321
11th Gen Honda Civic USB C MOD FOR SI IMG_0322
11th Gen Honda Civic USB C MOD FOR SI IMG_0323
So unfortunately this mod isn’t currently possible unless you want to swap out the wiring harness or come up with your own custom adapter (which I’m not even sure would be possible).
