Installed my dashcam (Blackvue 900X Plus), removed dealer sticker, hardwired my Uniden R8.
I pulled the wheels off and cleaned them. The front lug nuts were torqued to around 140ftlb so imagine the dealer did this when they took out the shipping blocks.
140 ft lbs!!!??? Do the Honda technicians frequently service Chevy Silverados at that dealership or something??‍♂
Riko
Erik
Belgium, Ghent
Civic FL4 e:HEV, Advance, Platinum White Pearl.
I added the following interior lighting to the FL5:
1. JDM OEM LED Tailgate Light (08E17-T43-000) - this LED light is a net new light located just below the left tailgate grab handle. This part is a complete kit that consists of wiring harnesses, LED light with switch, zip ties, template to make the cut, bezzle/housing for the light, foam inserts to prevent rattles, and other miscellaneous components. A+ quality kit with literally everything you need to install the light. I expect nothing less from Honda. What's interesting is when you remove the panel and flip it over, it's already premarked for where this light should go (see picture). In total, this takes 2-3 hours to complete properly if working at a leisurely pace.
@Clark_Kent
I managed to get hold of the (Japanese) instructions for the tailgate LED from JDM Yamato:
The instructions are somewhat scary in the sense you seem to have to remove a lot of trim pieces o_O
I get it you gotta remove the inside trim of the hatch, the bottom boot, and the inside rear of the boot, and the right inside.
But why remove parts such as the B-pillar, trim bellow the rear seats and grabhandle? ?
Did you too remove those parts? or can you actually skips a few steps from the manual?
screenshots of the manual from steps I dont get why they have to be removed:
11th Gen Honda Civic What did you do to your FL5 today? B1
And is is necessary to remove the right C-pillar where the speaker is located as shown here?
11th Gen Honda Civic What did you do to your FL5 today? speaker
because you seem to need to remove it to get the new A-harness thru, but again, can it be done without remove all these trim pieces I wonder?
Did you do it?
And last thing that was not clear to me.
One car connection all of a sudden appeared out of nowhere it seems:
11th Gen Honda Civic What did you do to your FL5 today? kabel
you have to connect that connection to the second B-harness.
But in all the steps, it didnt show where this car connection came from, this was just dangling around on the right side of the boot than?
I guess I wanted to know if you followed every step of the instructions because some seem unnecessary....but than again, you already did it, and I have yet to receive my Civic ?
Thanks a lot!
arsing116
Adam
23’ GRC CE, 23’ Civic Si (Sold), 14’ Evo X GSR
Yeah I just stopped at 140lb. They definitely used that air gun and zipped then on. The rears were no where near that.
Timmmmmm13
Tim
Chicago
Mazda 3 2014
11th Gen Honda Civic What did you do to your FL5 today? 1000008113
Just a heads up for new Jersey and finally Chicago area. Emailed them about Chicago. From 10am to 2pm. First come first serve. I also preregistered for the flashpro/jailbreak combo which gives you 20% off.
deadlyfishes
Matthew
Los Angeles, CA
matthewpablo.com
Added front and rear EVS towhooks. The front one wasn't so bad after carefully reading the instructions and watching GridZilla's video on how NOT to install it lol. The rear one I had to make a decently sized hole to keep the panel on. I ordered a separate panel in case I want to remove the tow hook.
11th Gen Honda Civic What did you do to your FL5 today? IMG_1680 3
11th Gen Honda Civic What did you do to your FL5 today? IMG_1682 3
Mine is getting here next week. Will be putting them on soon.
TchnoZ33
Zaid
Indiana
Thanks! You’ll see me there then maybe!!!!
50Cal_Actual
John
Virginia
2024 CW FL5 Type R; 2026 Passport T/S Elite Blackout
Picked up these SuperSpeed RF05RR wheels from forum member abellp and installed them when I got home. Great to meet another Type R owner in the DMV!
Having 18's on here now definitely makes me consider lowering just a touch... ?
11th Gen Honda Civic What did you do to your FL5 today? New Wheels
