Installed OEM CF wing and TSP locking screws lol
I like my OEM high wall mats but decided to get tuxmats to cover dead pedal..
Looks good. Any chance you can take a few more pics of it from different angles?
I can’t decide between the OEM CF wing and the Spoon wing. They are very different but it’s the only 2 wings I’m really interested in.
The problem with the Spoon wing is that it is very aggressive and feels out of place if there are no other body aero to go along.
If you have not already, you may want to give the Varis ARISING-1 Carbon+ Rear Wing a look. It weighs approximately 3.3 lbs lighter than stock and it's not too ostentatious. I think it could look fine without the other body pieces. FYI - the OEM Carbon Fiber Wing saves 1.6 lbs over stock.
RUNN1N
Who has this Ostentatious wing in stock? Sounds like it might be what I've been looking for. ?
I'm the weirdo waiting on the Mugen wing because I like them giant and silly.
I also like this wing but it needs other aero parts. Once I saw the other pieces, I decided this wing is no longer an option for me.
@Clark_Kent I’ve seen the Varis rep wing in person. I don’t like it. Specifically, I don’t like the 2 flare outs on the end plates. I am picky but thanks for the suggestion.
I do like the Varis GT wing. I can’t really decide hence I have not ordered anything. Right now, I like the slightly larger wing. But seeing how I have modded my S2000 since buying it new, my preference changes as I age. For now the Spoon and Varis GT wing looks cool, the “old” in me says, OEM CF wing. I think I need therapy.
Integra23
2023 Integra 6spd A-Spec
I wouldn't say failures, the coolant leeches out a little in some instances. But maybe there have been some legit failures where it dumped the tank contents all over the place that I just haven't seen online. Radium makes some high quality stuff so that would honestly surprise me.
I used a thin coat of RTV before joining the (2) halves of the Radium tank. Only about 3k miles on it so far but zero leaks, which I can't say about the OEM tank. My OEM coolant tank failed in under 3k miles...
I have seen many report issues with the rubber seam and the clear sight tubes. If you don't care about leaks then just keep the factory tank. A small crack will perform similarly.?
sugarl4nd
Andre
Sugar Land, TX
2023 FL5 CW & 2021 FK8 LE Phoenix Yellow
Busy last weekend:
Pumped-in exhaust audio delete
Mugen shift knob & Acuity shift boot collar
PRL Stage 1 kit
Covered Footrest (don't mind the dirt)
& a track day
For Pumped-in exhaust audio delete, do you have to remove the front grill trim ? Or you can remove the glove box only ? Wanted to do this delete also, it's super annoying.
johnny.silva7
Jonathan
Austin
(FL5) Civic Type R, Viper TA
You don't need to remove the grill trim. You can just have the plastic piece at the bottom still connected around the HVAC controls (shown below) and you'll just bend the plastic a bit. It'll be tight, but doable for sure. Wish I would've known before pulling it apart lol
11th Gen Honda Civic What did you do to your FL5 today? 1000032742
EVS Tow Hook installed. Was a bit of a pain
It really sucks that there’s no better solution than to cut and drill to get this front tow hook on.
