artsyfartsyFL5
Ant
PA
www.instagram.com
2025 CW FL5
Decided to finally install the Acuity 4 Way Adjustable Shifter. Had this originally installed on my Sport Touring.
The FL5 OEM shifter already felt great, this just makes shifting feel even better. I forgot how good this shifter is.
I just snagged this during black friday. I was on the fence since the OEM shifting experience is butter IMO, looking forward to this along with the ChasingJ's shift boot delete plate.
CafeApex
AZ
2025 BB FL5
is it possible to do one of these and keep a boot?
If you’re taking about using the Acuity shifter with the stock shift boot, yes you can. You just need to adjust the shift knob height to a level that won’t cause the boot to interfere, mine is between 2 and 3, closer to 2. It’s just a little bit lower than stock shift knob height.
jdezee
Jack
sanford, FL
Added black control knobs and a Create Carbon console cover - both procured from forum members.
Im glad it made it to you. I am the seller on Ebay. You could have always just hit me up on here!!
Its a great piece!! It was made by Carbon Sixth Element by the way. You snagged it for less than 50% of what I paid and no tariffs!! Im just glad its getting shown off.
jdezee
Jack
sanford, FL
APR Diffuser installed! Definitely one of the most expensive of all the diffuser options, but it builds on the OE's design versus being a full departure, which is what I wanted. Full Dry Carbon also adds cost, but the benefit is that it only weighs 2.9lbs :)
I did lose access to the rear toe hook, which isn't important to me
Before and After
I assume you loose access to the rear jacking point also?
onepointsix
Toronto
TW FG2 & SGP FL5
post up some more pics if ya can! I was curious how the material was vs Overland Designs since they wrap the actual trim cover
Here's some additional pictures, I'm just getting around to installing it. Note that it does not cover the entire piece. There's a section in front of the wireless charger that sticks out but you'd never see it. Took a picture for reference.
11th Gen Honda Civic What did you do to your FL5 today? IMG_7102
11th Gen Honda Civic What did you do to your FL5 today? IMG_0006
11th Gen Honda Civic What did you do to your FL5 today? IMG_7105
11th Gen Honda Civic What did you do to your FL5 today? IMG_7103
11th Gen Honda Civic What did you do to your FL5 today? IMG_7104
artsyfartsyFL5
Ant
PA
www.instagram.com
2025 CW FL5
quality looks good, I was on the fence compared to overland designs since they do quality work. May end up doing this
madbikes
SF Bay Area
Lug nuts came and put on the new wheels.
5 percent gain in sidewall (or 19 percent by actual thickness) definitely make bumpy backroads far less jarring to drive, and ride quality felt more like a normal car everywhere. I do miss the way the stock 19s drive though.
11th Gen Honda Civic What did you do to your FL5 today? 20251207_161537
Deleted User 3888
Ooooh. So the wheel appears to be fine. It lays perfectly flat on both sides. But both front tires are fucked. Literally blew apart where the side wall meets the shoulder blocks. Typical Continental shit.
both new tires get delivered today. They’ll be installed Thursday. Gonna put the wheel onto the balancer. Just to make sure there really aren’t any issues.
