TheFactor
Factor
So Cal
2025 CW Civic Type R
Took her to Costco for some premium ?
11th Gen Honda Civic What did you do to your FL5 today? IMG_2276
Tried cutting the plastic panel covering the rear tow hook. Made way too generous of a cut. Thank god it’s a $5 mistake. The EVS tow hook does look good.
TheFactor
Factor
So Cal
Pictures or it didn’t happen ???? :)
+1 pics please. I have the spare part sitting around, I need to cut it too cuz its a pain in the ass to remove. I normally don't like tow hooks but the straps that are for sale are so damn expensive.
I will share the picture of the next cut. I’m a little embarrassed to post this one. ?
TheFactor
Factor
So Cal
Don’t blame you lol
Just remember measure twice and cut once this time ?
WeudS
Daoud
MA
2023 RR CTR, 2023 MDX Type S
Should of taken some pictures but installed my Hasport rear motor mount and knocked out my 25k oil/filter change and tire rotation.
It’s not hard to remove if you have the prying tools. Look at the new part and where the tabs are. Pry the top 2 tabs and it will come off easily.
I did use a prying tool but maybe its too big, did not want to come out and did put a tiny mark on the diffuser
TheFactor
Factor
So Cal
About 3 months old and just over 600 miles ?
Gave her a bath and getting ready for a ride to the beach????
11th Gen Honda Civic What did you do to your FL5 today? IMG_2287
11th Gen Honda Civic What did you do to your FL5 today? IMG_2285
11th Gen Honda Civic What did you do to your FL5 today? IMG_2286
TheFactor
Factor
So Cal
Forget the beach. Head to the mountains lol
Great advice ????
EDIT :
But you won’t see this beautiful eye candy Hot Rod Lincoln on the twisties ?
11th Gen Honda Civic What did you do to your FL5 today? IMG_2295
11th Gen Honda Civic What did you do to your FL5 today? IMG_2294
11th Gen Honda Civic What did you do to your FL5 today? IMG_2293
Or This and what I can’t appropriately post here ?
And the stairway to Heaven :)
11th Gen Honda Civic What did you do to your FL5 today? IMG_2297
11th Gen Honda Civic What did you do to your FL5 today? IMG_2299
11th Gen Honda Civic What did you do to your FL5 today? IMG_2298
11th Gen Honda Civic What did you do to your FL5 today? IMG_2296
svvitch
Let's see
Changed oil for upcoming track weekend
Bleed brakes w ate type 200
Installed 27Won rear motor mount
Checked to see if rear sway bar was tight it's been making some noise RV6 bar and end links. Everything right still some clunking.
Installed FX3D rock guards front and rear
I used one that looks like a Y do it came off rather easily.
I attempted to make cuts on a new cover but when I went to the one I did yesterday to see where I can make smaller cuts I just don’t see much other than the top where I could have not cut as high to show the white panel. Otherwise, there’s not much to “cut less”. I actually need to cut a little more on the left.
The lower portion is where the wrench would go to tighten and the top needs clearance so the tow hook can rotate the thread into the stem.
11th Gen Honda Civic What did you do to your FL5 today? IMG_1911
11th Gen Honda Civic What did you do to your FL5 today? IMG_1910
