DustyDan
Dan
New Jersey
Went to change the engine oil and found the underside of the car looking like this! Had a slight panic attack. Turned out to be transmission oil leaking from the axle seal. I checked for weeks after the springs install and saw no leak, but I guess I did nick the seal. Pretty common, so make sure you check if you did coilovers or springs.
11th Gen Honda Civic What did you do to your FL5 today? IMG_6615
Tore apart the front suspension, pulled out the axle and replaced the axle seal, swapped in AC Delco trans fluid, and took the opportunity to pull the strut pins this weekend
Pic for fun
11th Gen Honda Civic What did you do to your FL5 today? DO8A1903
11th Gen Honda Civic What did you do to your FL5 today? DO8A1920
dathoneycomb
W. MI
2023 FL5 Type R CW
Do people pull the strut pins even if you’re not tracking the car? Any negatives to doing it?
DustyDan
Dan
New Jersey
You'll only get about -2 degree of camber at most which is fine for street driving. negatives would be that you will feel some more tramlining from the car and maybe a tiny more tire wear. And don't forget to get an alignment.
princers
Z
25 Type R
Installed Remark exhaust, RMM, and spacers over the weekend.
how do you like it so far? great build quality/price point/sound from clips I've heard so definitely a solid option for those who don't want the 3 tips
jpindustrie
JP
2025 SG FL5
Not today but the other day while hanging out at my friends wrap shop they convinced me to try pinstripes, wasn’t originally going to but once they were done they’ve slowly began to grown on me. Def helps mine stand out
11th Gen Honda Civic What did you do to your FL5 today? IMG_0778
11th Gen Honda Civic What did you do to your FL5 today? IMG_0764
Received the TSP downpipe (Raw) and sent it right back out for a proper coating (Swain Tech).
11th Gen Honda Civic What did you do to your FL5 today? 1742953383099-ik
