Vincent@27WON
REDEFINE the Aftermarket
- First Name
- Vincent
- Joined
- Nov 24, 2017
- Threads
- 86
- Messages
- 1,499
- Reaction score
- 1,132
- Location
- Las Vegas, NV
- Website
- www.27won.com
- Vehicle(s)
- 17 HBS, 18 SI, 18 CTR, 14 Ridgeline
- Thread starter
- #1
I wanted to share this great piece of information from Derek at IMW. He created this comment in a Facebook group and it contains solid info that is worth re-posting and sharing. So check out these useful definitions and come back for more.
Thanks D-Rob
"Knock Count" = This parameter is a reflection of the ECU's misfire monitor. It is NOT an accurate reflection of anything other than misfire events. When will you see these normally? Startup, rapid throttle closures, rapid throttle inputs, rapid release of the clutch pedal, and sometimes at idle (especially if you have a lighter flywheel/clutch combo, and/or plugs that have been gapped down to prevent spark blowout at high load). A completely stock car, operating perfectly will still accumulate these counts. In my experience with these engines, you will see more activity on cylinder four compared to others, as the crank position sensor is physically located closest to there on the block. This usually isn't a concern area unless you see a steep count in a very, very short time (like 50+ in a few seconds), which will likely trip a P0300-variant DTC code.
"Knock Control" = This parameter is the ECU's determination of fuel quality. Movement here indicates the knock sensor hears what it thinks is knock activity, and reports to the ECU to apply a steeper ignition retard to avoid continued knock activity. This value is dynamic, and WILL move from time to time. On Civic Si models, there doesn't seem to be a forced rise at play at WOT like the non-Si 1.5T ECU's (which naturally rise above 5,200-5,400rpm regardless of sensor input). Movement that goes up and up and up and never comes down is more concerning than movement alone. Knock control can typically be manipulated down by driving the car in a higher gear at lower engine speeds and targeting atmospheric pressure on the MAP sensor reading.
Thanks D-Rob
