What type of gas 87 or 91
Testa_Rossa_
23 CW CTR
She get's nothing but 93 from me. I'd rather just fill it with the best then have it develop an issue or otherwise. Just makes sense and it's one less thing to think about.
CatD10
Southwest Indiana
2024 Civic Type R, 2008 Civic, Ram1500
Spark knock isnt always audible either, when it occurs the gasoline is exploding rather than burning. What can happen?
Blown head gaskets
Cracked pistons
cracked piston rings
Damaged Connecting rod bearings, rod bearing damage is the most common with knock but not always noticeable until later in the life of the engine.
It's your car do what you want.
Greas
Jason
2023 Civic Type R (sold), 2006 Lancer Evolution IX
This thread is a helpful reminder for myself for why I bought new instead of used.
thatonedaveguy
Dave
Texas, USA
24' CW Civic Type R #18788
93 octane only, octane boosters cause issues.
From my tuner: NOTE: Do NOT use octane booster. Octane boosters have corrosive additives like MMT which cause spark plug and injector problems.
I’ve never used octane boosters, but after reading around a bit, not all octane boosters have Methylcyclopentadienyl manganese tricarbonyl (MMT or MCMT). MMT is not corrosive, BUT it can cause some buildup on the spark plugs. Likewise it also puts a bit more wear and tear on the catalytic converter.
Apparently a good booster is in fact ethanol (as mentioned earlier). It seems to me that mixing your own fuel may not be trivial, but I don’t know. Maybe it’s simpler than I’m thinking.?‍♂
SKINNIE
DFW TX
ISF, 23' BB FL5
So people are recommending to run 87 with octane booster to save $9-$15 per tank. Also running octane booster WILL damage and foul out your spark plugs.. WTF ? ? ? ?
Makes a lot of sense.
This and it will likely be zero sum. Last I checked octane booster isn't inexpensive.
LOL! Was just trying to think of an alternative if 91+ is ridiculously cost prohibitive in some parts of the world. I didn’t know enough about it to say it’s a “good” alternative. Turns out it’s probably not, based on cost and the fact that some octane boosters may also provide a boost to spark plug wear.?
Websitesdown
I have come across 92 somewhere before. Don't remember where though.
Yeah…I feel like I’ve seen that too. That’s what I meant by 91+ (to cover the bases 92, 93, etc)?
Websitesdown
I for the life of can't remember off the top of my head.
Found this chart.
StateRegular UnleadedMid-Grade UnleadedPremium UnleadedNotes
Alabama878993
Alaska8788.590
Arizona878991
Arkansas878991/93Northwest Arkansas primarily sells 87/89/91 octane. 93 octane is available at select Kum & Go's in the Northwest and Central regions of the state.
California878991
Colorado858791
Connecticut87899386 octane may be sold if labeled as economy[1]
Delaware878993
Florida87 [2]899391 octane premium is sold at select stations alongside 93 octane.
Georgia87 [3]8993 [3]
Hawaii878992
Idaho85/8787/8991Octane ratings in Eastern Idaho are 85/87/91 in Western Idaho the octane ratings are 87/89/91.
Illinois87 [4]899193 is widely available in the Chicago area. Elsewhere in Illinois, 93 is offered at Shell and select other stations. Many fuel stations now offer an 88-octane fuel blend that is 15% ethanol, suitable for use in some gasoline-powered automobiles from model year 2001 and newer.
Indiana878993
Iowa878991Many stations will offer "Super Unleaded" 87 that contains 10% ethanol and a more expensive "Unleaded" 87 with no ethanol. 93 is available at select Kum & Go and Murphy USA / Walmart locations.
Kansas878991All BP Stations offer 93 octane gasoline
Kentucky87 [5]8993
Louisiana878993
Maine878991 without ethanol 93 with ethanolPremium gas must be at least 93 octane if it contains 10% or more of ethanol
Maryland878993
Massachusetts878993
Michigan87899385 and 86 octane may be sold if labeled as subregular[6]
Minnesota878991110 octane fuel may be available at certain locations in southern parts of the state.
Mississippi878993
Missouri878991/93Some Phillips 66, Break Time, and Conoco stations sell 91 octane premium. Southwest Missouri in the Ozark Mountains and Mark Twain primarily only sell 87/89/91
Montana85.5 [7]8891
Nebraska878991
Nevada878991Eastern Nevada primarily uses 85/87/91 octane ratings.
New Hampshire878993
New Jersey878993New Jersey checks for fraudulent labeling of octane ratings.[8]
New Mexico868891
New York87 [9]8991/9393 is widely available.
North Carolina87899391 octane is commonly sold as "premium" in the western, mountainous part of the state.
North Dakota87 [10]8992
Ohio878993
Oklahoma878991
Oregon878992
Pennsylvania878993
Rhode Island878993
South Carolina878993lower octane gas can be sold if labeled as "sub-standard" or "sub-regular"[11]
South Dakota85/8787/899185 octane must be sold with a warning label displayed at the pump.[12] 85 and 86 octane can be sold as regular fuel only in the counties of Butte, Custer, Fall River, Harding, Lawrence, Meade, Oglala Lakota, Pennington, and Perkins.[13] 87 and 88 can be sold as mid-grade in the previously-named counties.[13]
Tennessee878993
Texas878993El Paso, Lubbock, and Amarillo areas have 86/88/91 octane ratings.
Utah858891
Vermont878993
Virginia878993
Washington878992
West Virginia878993
Wisconsin87899193 widely available
Wyoming858891
I got it in Washington on a vacation. I say OP goes with 85 and be a test dummy for everyone. ?
