Will the TSP high efficiency downpipe fit with the frontpipe included with the AWE touring exhaust?
getGroyped
Josh
I have had two people try to connect the TSP high efficiency down-pipe to the AWE front-pipe and they have both experienced these two issues:
1. There is a gap between the downpipe and the frontpipe
2. Even if the frontpipe/downpipe could connect, it seems that there isn’t enough clearance for the frontpipe because the oil pan is in the way. The installer is insisting that even if we disconnected the frontpipe from the rest of the exhaust.
I’ve attached some pictures from the installer to better illustrate the issue. I have burned through hundreds of dollars trying to get this to work, so any thoughts or advice would be greatly appreciated here.
11th Gen Honda Civic Will the TSP high efficiency downpipe fit with the frontpipe included with the AWE touring exhaust? 6c90f1ab-a58c-486b-8d3e-97a8f0effc8
11th Gen Honda Civic Will the TSP high efficiency downpipe fit with the frontpipe included with the AWE touring exhaust? 1fe7ec34-5677-489d-ae9d-4ddc6e22124f
11th Gen Honda Civic Will the TSP high efficiency downpipe fit with the frontpipe included with the AWE touring exhaust? 85c07c7c-bf24-4933-8580-9f8422d5a72c
11th Gen Honda Civic Will the TSP high efficiency downpipe fit with the frontpipe included with the AWE touring exhaust? 6bfa1510-c6fb-4dab-a1df-cd4b26d92c5d
11th Gen Honda Civic Will the TSP high efficiency downpipe fit with the frontpipe included with the AWE touring exhaust? 90519647-42c7-419d-8360-bd4dd56bb759
evlsmurf
2016 Subaru Impreza Sport
Damn! I wish I could help here. I was considering that DP to go with my Invidia exhaust. I wonder why it doesn't mate?
getGroyped
getGroyped
Josh
Here’s another photo of the frontpipe hitting the oil pan.
11th Gen Honda Civic Will the TSP high efficiency downpipe fit with the frontpipe included with the AWE touring exhaust? eb4649fd-58cb-4ff4-a0c7-7506e8afe678
getGroyped
getGroyped
Josh
Did you have the exhaust on with the stock DP?
Yes, the AWE frontpipe was able to meet with the stock downpipe. I’m thinking that I should reach out to TSP and ask for their downpipe dimensions to ensure that my downpipe isn’t a lemon.
evlsmurf
It should definitely work then unless the DP is wrong.
Savannah@TSP
www.twostepperformance.com
'23 Si, '98 EJ6, ‘20 FC4 (sold)
I assume you've tried backing out that turbo to downpipe exhaust bolt a tad bit, and connecting the frontpipe first?
I found that keeping the connection loose at the turbo (thread in the bolt a little less than halfway) then connecting the frontpipe to downpipe goes smoother. From there you can add the brackets (loosely) then connect to the turbo. However, if it's hitting the oil pan, that's not ideal.
I'm not trying to point fingers here or cause additional frustration, but I'm really thinking this is an install issue. We haven't changed the jig, so any variance would be shocking.
Once you've tried this method, and if it still does not line up, please email us so we can work on getting it inspected.
getGroyped
getGroyped
Josh
Thank you for your input, I don’t know if the installers had tried this and I suspect that you’re correct. I will be trying the installation myself to see if I can get it attached.
nattypiso
Dom
Fayetteville, NC
FL5 CW R-05536
Sorry to hear you’re having issues. Currently have TSP’s high efficiency Downpipe paired with AWE’s catback exhaust system, perfect fitment in my situation with no issues. Did the install of both the DP and Exhaust myself (Downpipe first, then Exhaust). TSP’s customer service is very helpful in the event that you’re unable to resolve the problem.
Snmtazz70
Type R
Just received my TSP downpipe. Installed myself, fit perfect with AWE Touring exhaust. No issues. Replaced bolts and nuts with the titanium ones. Spray Krill oil worked great for stock bolt removal.
11th Gen Honda Civic Will the TSP high efficiency downpipe fit with the frontpipe included with the AWE touring exhaust? 1000022943
