chopsuey34
- Joined
- Jul 20, 2022
- Threads
- 19
- Messages
- 338
- Reaction score
- 252
- Location
- West Michigan
- Vehicle(s)
- ex-Meta, ex-AWS, ex-2025 Honda Civic Si
- Thread starter
- #1
OEM+ “NA” build
(In this thread, we don't just build cars but relationships with them, too.)
My goal is to put some money into my Si and turn it into “what it should have been from the factory”. But in doing so, I don’t want to fundamentally change its character or power. If I wanted something more powerful or different, I would have just bought that something else.
This is my first Honda. I’m not a Honda guy, and I’m not a VTEC, 90’s golden era Honda fan boy, either. I also don’t like torqueless, high revving engines, the kinds that Honda was famous for building back in the day. But I am an “NA” guy, and this is my first turbo.
With my build, I want to replicate a naturally aspirated engine, meaning I want as much throttle response and as little turbo lag as possible. I also want to avoid the temptation of abusing the turbo and turning the L15CA into a torque monster with a camel hump dyno sheet. Instead, I want to aim for a “mini V6” feeling that I believe the 1.5T is capable of: more, linear power. And in fact, I don’t need much more power at all. I’d rather some more response than anything. I’d rather use 100% of 200hp (or 220hp) than 70% of 315hp.
Good opinions and new points of view are always welcome (please be civil, though)
I’m using this thread as an information dump for myself as well FYI.
I hope you enjoy this build.
Engine
PRL Rear Motor Mount (PRL-HC11-RMM) – great!
PRL Resonator Delete Kit (PRL-HC11-RES-KIT) – useless
PRL 1.5T Silicone Intake Hose Upgrade (PRL-HC11-15T-INT-HOSE) – useless
Sprint Air Filter (P1137S) – a little more power, maybe?
Tune
Phearable 1.5R - mixed feelings
Cooling
PRL Intercooler (PRL-HC11-IC) – haven’t heat soaked yet! Edit: only if necessary.
HPT WOT Performance Cool Plate (FL5/FE1) – high quality
Transmission / Shifter
Acuity Stage 2 Shift Kit – love it
Throttle Pedal Spacer (Acuity #1919) – hated it, uninstalled & returned
Suspension
PRL Rigid Collar Kit (PRL-HC11-SRS) + Alignment – not sure if I can feel the difference
Wheels
Enkei TS-5 18x8.5 +38 (Bronze)
Continental DWS06+ 245/40R18
45.2lbs vs. 52.6lbs stock (~30lbs unsprung weight saved)
- Stock size for reference – 18x8 +50, 235/40R18, 5x114.3
Exterior
Honda Black Emblems (08F20-T20-100) – only rear badge applied
Honda Door Edge Film (08P20-T20-100A)
Honda Door Handle Film (08P48-T20-100)
Honda Rear Bumper Applique (08P48-T20-100A)
Honda Door Sill Metal Protection Film (08F05-TVA-100)
Honda Side View Mirror Covers (76251-T20-A01ZB & 76201-T20-A01ZB)
Honda “Tear Ducts” (71202-T61-A51ZE & 71207-T61-A51ZE)
LASFIT LED Bulb Turn Signal Light Amber (T3-7443A) – well-known brand in CivicX and CivicXI communities
LASFIT LED Bulb Reverse (Light L-T15)
Sukeban Mudflaps (Deluxe Black) – good product
Interior
Honda Cargo Hooks (08L96-TA0-101A) – useless, plastic grocery bags from Meijer aren’t tall enough
Dash Cams (Front & Rear – Rove R2-4K Dual) – satisfied
LASFIT LED Bulb Trunk Light (L-T10)
Accessories
Honda Euro Horn (08P80-T43-000) – sounds better than stock (“hoooonk” vs. “eeeeee”)
Tuxmat Floor Mats (Front #8701 & Rear #8701-T1) – high quality
Silicone License Plate Frame (Amazon)
Screen Protector (Amazon)
Future Mods:
Spoon Springs (51400-FE1-001) – probably not, because this is a daily and I don’t want my car any stiffer. But these are the only springs I would run if I chose to do so because they are similar to stock and only drop an inch or less
Weighted Shifter?
Engine
Tune
Cooling
Suspension
Wheels
Exterior
Interior
Accessories
Future Mods:
Weighted Shifter?
