27WON Civic Si Time Attack Build
st4xor
Eric
Washington DC Metro Area
2020 Civic Si Sedan
So I pulled a front wheel to access the front caliper and had intentions of pulling the pads to measure, but to my surprise the caliper had a large retaining clip holding the body of the caliper to the knuckle/caliper bracket. Of all of my many Honda cars I've owned and serviced, I've never seen a design like this. Where the caliper bolts holding the piston and body part of the caliper there were the plastic cylindrical coverings of some sort. I didn't want to dismantle the caliper to find I needed a special tool to put it all back together. :) Anyone service a caliper like this?
Hmm, I think I understand the Unity Performance picture now. I guess the Unity picture really is comparing a 10th gen Si stock pad (top, EBC yellow) to a stock 11th gen Si pad (bottom).
I can tell from the pad ears poking out of the caliper in your 3rd picture that the 11th gen stock pad is definitely different from the 10th. And the ears look the same as the bottom pad in the Unity picture. And then in my picture, the rear pad is much smaller than the stock 10th front.
So unfortunately, no dice, looks like the 11th gen Si pad really is different from the 10th gen pad. As a 10th gen owner I'm pretty bummed, too--was hoping Honda would re-use the same caliper which would hope pad availability for both gens (like the 8th/9th crew). Wasn't meant to be, I guess!
That retaining clip you found looks to me like it is just a basic spring. So some sort of flathead and/or pliers should be all that you need. I wouldn't be too worries about it when the time comes.
Having someone send a stock pad backing plate to Carbotech or G-Loc is probably the best way to get access to decent performance pads.wothout going to a BBK.
I'm going to be moving to a carbotech XP-8 for my next track day later this year with my 10th gen. Carbotech already has the 10th gen Si stock backing plate info in their system. I did a powerstop "track day" pad for my first outing and they held up fine-ish. No brown trousers moments, but they were pretty much used up after one outing and the braking confidence was never really there.
Hopefully a good Carbotech/G-Loc pad will do well for track days with stock power on the stock caliper. Otherwise, the 27won BBK is definitely a favorite for the 10th gen platform... I expect the 11th gen community will find the same!
OGGsr
Jamie
Richmond VA
PWP 2022 Civic Si
Yeah kind of a bummer there aren't any readily available pads for this car yet. I watched a youtube video of an Si owner doing a track day with his car and the biggest issue was the lack of braking and a soft pedal after the event. Car and Driver also measured something like a 300 foot stop from 100 mph. When I had my old GSR, I put Accord Wagon/ITR calipers with VW Corrado rotors and Porterfield R4S pads. Great street/light track day setup.
Tobiman
Oluwatobi
The Bronx, NY
2021 Honda Civic Sport Hatch
This looks very similar to the new accord. It seems Honda brought over a lot of parts from the Accord for the new Civic.
Vincent@27WON
Vincent@27WON
REDEFINE the Aftermarket
Vincent
Las Vegas, NV
www.27won.com
no special tools needed. That spring literally just pops on and off. Use a flat head.
evanescent03
ITS, C8 Z06; great pairing
thanks for sharing your experiences with the car! i'm coming form a camaro SS1LE most recently as my track car (track days with Chin, HOD etc) ... waiting on a C8 ZO6 or GT4 allocation but i'm thinking of running the Si for a couple of events ... looking to do brake pads and tires to have something reliable but not necessarily blazingly fast. i'll definitely be following this thread while also looking around for an adequate pad and tire (or wheel/tire) option.
sackofcheese
Andrew
Central KY
2022 Civic SI, 1994 Miata (track toy)
Honda uses DOT3, so switching to something like Motul RBF660 or Castrol SRF would probably help the mushy pedal. I plan on flushing my fluid with the Motul stuff once it gets warmer out.
Vincent@27WON
Vincent@27WON
Vincent
Las Vegas, NV
www.27won.com
For those more price sensitive the Motul RBF 600 and Hawk HP 600 fluid are ones we have both used that work well for time attack sprints.
Vincent@27WON
Vincent@27WON
Vincent
Las Vegas, NV
www.27won.com
Vincent@27WON
Vincent@27WON
Vincent
Las Vegas, NV
www.27won.com
DYI01
Dan
MD
@Vincent@27WON Since you have experience with both the 10th and 11th gen civic brake systems. Do you know if 10th gen stainless steel brake lines will fit the 11th gens? I'm looking to upgrade the brake lines on my 11th gen Si.
Vincent@27WON
Vincent@27WON
Vincent
Las Vegas, NV
www.27won.com
Yesh they would work.
sackofcheese
Andrew
Central KY
Anyone know how much brake fluid I need for a full flush? I have an HPDE session Friday and don't know how much to get.
I used just under 1 bottle of the Motul RBF600. I would get 2 just to be safe though. Have you swapped pads yet? As far as I'm aware the only option are the Carbotech ones. Hawk wont have pads until December at the earliest.
StickShiftRoy
Roy
Greenville SC
22 BOP Si (Sold), 19 CW FK8 (Sold), 24 CW FL5
Good to know! I'm on stock pads at the moment, those will have to wait till next month unfortunately.
