Drive mode switch bezel
Ohlins8990
IL
FL5, 3G MDX
Is anyone else seeing this switch bezel crack. Noticed it this week and no idea when it would have happened since I have mostly kept the car in one drive mode. Real annoyance is that its not just a bezel, but only available as the whole switch pack (35730-T60-C01). My thought is that the hot/cold temp cycles cause it to crack at this point.
11th Gen Honda Civic Drive mode switch bezel IMG_9767
ChangeYourOil
Earth
Car
Weird place for a crack like that. I'm a little doubtful that temp change could do that. It would have to be extreme. But you never know.
Do you normally take your car to the dealer or another shop for service or anything?
Maybe it happened at that time.
Hot/cold cycles will not cause automotive plastics to crack like that, not even sub zero temps. You’d find cracks in other areas too, if that was the case. I think something got dropped on it. Just to be sure, are you positive it’s a crack and not a deep scratch? Almost looks like maybe a blade (like a box cutter) sliced it.
Ohlins8990
IL
FL5, 3G MDX
Definitely cracked all the way through. About the only thing that would have touched it is a microfiber to 303 protectant on it.
Ohlins8990
IL
FL5, 3G MDX
First of all, I want to thank Chilly613 for helping me out with a replacement.
Second, after taking a closer look at my old one, it looks like its the same switch bezel as the Acura Integra (35730-3S5-A01). There are a couple tabs holding in the switches themselves an can pretty easily be popped out to replace the Integra switches with the Type R ones. Not sure why Honda doesn't just sell the plastic piece, but either way the Integra switches are way cheaper and dont have the Type R tax. Hope this helps someone else out in the future.
Ohlins8990
IL
FL5, 3G MDX
Had issues with this switch again. Definitely not dropping things on it, so no idea what’s going on. Dealer is getting a call in the morning, though I’m guessing they won’t do anything.
11th Gen Honda Civic Drive mode switch bezel IMG_0247
11th Gen Honda Civic Drive mode switch bezel IMG_0284
Xmetal
CTR, S3
That is really weird to have it happen to two different modules and in different areas! I don't think I've ever seen anyone mentioned this happening anywhere.
Ohlins8990
IL
FL5, 3G MDX
Update: Swapped in an Integra part. The bezel has some texture on it instead of being smooth like the Type R part. I was also able to swap over the silver piece of the switch from the Integra part when I was moving over the Type R drive mode switch in. It's a bit of a pain to get the actual switch apart, but was able to accomplish with a metal spudger tool.
