TSP Stage 1 while Stock(ish)
Websitesdown
I wonder if hondata has updated the tune at all to try and clean this up. Or maybe it's intentional to keep the AFR rich during that sudden transition.
I hope so, running it without knowing it's happening could be detrimental.
jmheath357
Phoenix, AZ
2025 Honda Civic Type R
Couldn't tell ya to be honest. I'm not sure if it's intentional or more just a normal momentary reaction to the sudden changes. Also, with the Hondata tune the commanded fuel pressure is only 2,600psi vs 2,900psi on the factory settings so that's probably part of why the duty cycle goes so high. It would probably be better with a higher commanded fuel pressure.
champ_white_FL5
Jim
New Mexico
2024 civic type r
Hmm interesting on the commanded fuel pressure! Can't wait to get my flash pro and start logging
jmheath357
Phoenix, AZ
That's why I never blindly upload any tune and just trust that everything is running correctly. Lots of people do that and have no idea what's going on behind the scenes. They just see advertised dyno results, upload a tune, and then assume everything is great because the car feels faster. You would never know what the fuel pump is doing, along with lots of other things, just by driving it.
Websitesdown
Mind you I'm not bashing tsp. I've purchased a lot of stuff from them but you'd think they'd have their tune tweaked enough to not have that happen, honestly. I'm going to guess the issue is related to elevation but if think they would think about and cover for that, that or a pressure leak on the user end?
I liked ktuner because I had a live screen showing my trims and knock etc right there constantly. Hondata, I don't have that right now. I have to hook up my flashpro to my obd connector then connect my phone then stare at my phone which I don't even have a phone dashboard holder for yet.
Just a lot of extra work.
champ_white_FL5
Jim
New Mexico
2024 civic type r
There are probably thousands of people running the tsp tune on 91 and not experiencing any issues, even if the ECU is experiencing slight knock. I'm sure there are ample protections in place on these tunes to prevent any damage.
At elevation you should actually have less risk of knock since the air pressure is lower.
Websitesdown
You'd hope so in regards to the safe guards. Cross your fingers and roll the dice I guess. You should never go over 95% fuel pump duty. Sounds like some are, and that's not good.
jmheath357
Phoenix, AZ
The fuel pump issue was with the Hondata 91 OTS map that someone asked me a question about, not the TSP Stage 1 tune. The TSP tune had no fueling or other issues at all for me other than an unacceptable level of knock retard since all I have access to is 91 octane fuel at the moment.
And yeah, I miss the live data on Ktuner like I had with my 2.0 Accord too. Hondata is lacking in that aspect for sure in comparison.
champ_white_FL5
Jim
New Mexico
2024 civic type r
Knock and fuel trims were good for the time I ran it, never saw any issues. The one issue I did see was the fuel pump duty cycle would spike up to 110% during WOT 4th gear pulls, and that was in roughly 50 degree weather. That said, I didn't see the AFR go lean (in fact it actually went rich) even though fuel pressure did drop slightly from the target. This was the main reason I decided to go ahead and get a custom tune instead of waiting until I could move back home where I would have access to 93. Although I think it was technically safe, I didn't like that. You will probably be fine but I would always recommend doing some data logging and make sure though.
Hey man who did your custom tune?
jmheath357
Phoenix, AZ
