Is the Hondata 93 map safe to run for a while?
lando
Jason
Pleasant View, Tn
(2025 civic type r) So I just flashed my car this evening, and i'm pleasantly surprised. I chose the 93 octane map, and the butt dyno felt an increase. I have two questions if anyone would like to help me out. First question, is it safe to run the 93 octane map for a while? Like maybe a few months, or should I go ahead and get a custom tune. The only reason why I want to wait is that I ordered the TSP dp. I was going to wait till I got that installed to get a custom tune. Second question, is there any where on the flashpro manager to select what parts you have on your type r. I know a few years back when I had a 2008 civic si, the flashpro would let you select what parts you have upgraded. Currently I have the eventuri intake and turbo inlet pipe. As well as the remark exhaust with front pipe.
Evox787
Elvin
You should aim for the custom tune at the moment you also start modifying your car. I have been running mine on the Hondata OFf the shelf map since summer 2025 if my memory serves me right, and so far everything seems fine. I will be doing my custom tune with one member here, Jester, due to the availability of tuners near me, and he has really good feedback here on the forum and is really knowledgeable by every little question I asked him. By saying that, the only mod I have and will put is a drop-in filter and maybe maybe the matte carbon infinity design inlet. Your second question, I think, on the drop box to choose gives you different options on 93 maps with different modifications and also to put the Type S "pop and bangs," but don’t quote on that; I really don’t remember; probably another member will correct me.
J_D
J
Montreal
Hondata OTS maps are very safe, you can literally run for the life of the car if stock. Even with certain mods, provided they don't require a tune in the first place on a stock car.
The downpipes will make no difference the Hondata tune. It will just affect the sound, the extra flow capacity will not be taken advantage of. Assuming you have the GESI cat you won't have an engine light either.
The Eventur intake I am not so sure - if the intake is certified to work without a tune it should be fine, because it will behave like stock which the Hondata tune expects.
champ_white_FL5
Jim
New Mexico
2024 civic type r
How has your experience been so far with the hondata OTS tune?
Higgs Boson
Texas Hill Country
you can run the hondata ots tune forever very safely. you want to consider a custom tune if you start to modify parts between the MAF and oxygen sensor, things that modify the volumetric efficiency of the engine or that surpass the limits of the torque model in the stock calibration or that might surpass the normal limits of the self check ranges that could set a CEL if not tuned out.
champ_white_FL5
Jim
New Mexico
2024 civic type r
So I should be fine with the PRL HVI and inlet? Those are my only mods except for resonator deletes and my fuel trims are excellent with the HVI usually +-3
Higgs Boson
Texas Hill Country
If your fuel trims are within 3 percent at idle and full throttle and everywhere in between then there's no issue. I am assuming the PRL intake diameter around and near the MAF is the same as stock? Have you checked your fueling at full throttle?
TchnoZ33
Zaid
Indiana
You don’t need to change your tune if you get an intake or DP. So if you are planning on a custom tune, I would do it. The base MAP is fine but when I had it, the power delivery wasn’t very smooth.
When I got my custom tune, it was way more smooth and predictable. You can fine tune once you have your intake or DP but it’s really not necessary to get another tune just for a DP.
I have added a DP, FP, intake since my tune and have made no changes and the car runs great. I’m sure I can send Jester my logs and he can optimize it. But, I plan on changing a lot more so I figure I’ll wait.
Unity Performance
Humza
Toronto, ON | Buffalo, NY
unity-performance.com
I've refused to run a basemap, so much so that I didn't bother tuning my FL5 from October until just this past week, when DRob was in town visiting and threw a slightly modified TSP Stage 1 tune on it.
When I tried the Hondata pre-loaded basemap on my FK8 years ago, I was 3mph slower on the back straight of my home track at the time, with barely any improvement in driveability to show for it. There was just a gob of torque early on, and then flat. past 5,500.
TSP and Phearable maps smooth out daily driveability and deliver power in a much more linear fashion. It only gets better when you upgrade to a drop-in, and can really tune it to where power keeps increasing to 7,200-7,400rpm, whichever your tuner sets it to.
J_D
J
Montreal
I ran a hondata basemap on a Gen 1 Acura RDX turbo K23 for over a decade. It was regularly beat on 24/7 in blazing heat and frigid cold, 0 issues.
I would have no issue running a Hondata basemap on a CTR.
