jcb
3000 mile OCI. Stock air filter. 20 micron oil filter (like a fram ultra class)...done. Good oil obviously. Brand probably does not matter. A good one.
A few rebuttals to this:Good oil obviously. Brand probably does not matter.
For sure use an API SP or SQ engine oil.A few rebuttals to this:
On that last point - Lake Speed had a video a while back that showed that for 0W-30, 5W-30, 0W-40 - you name it, shearing out of grade didn't actually lead to increased wear over a huge number of oil samples.
- You want an oil that will fight LSPI. The thing to look for here is API SN Plus or API SP.
- You want an oil that is suitable for a high-revving, turbocharged gasoline engine (Shell Rotella goofs, take a seat.)
- Brand (read: formulation) absolutely starts to matter when 0W-20 shears out of grade. Shearing out of grade is not something strictly related to mileage on the oil.
But 0W-20? Not the case. There was a very observable uptick in wear metals in the oil samples from cars running 0W-20 where it had sheared out of grade.
So don't just go with "change oil early" and "brand doesn't matter" - you need to add "API SN Plus or SP", no HDEO like Rotella, and if the particular oil formulation (brand and model) isn't widely known to stay in grade, bump up to 0W-30 instead of a 0W-20. Then you can truly live in brand-agnostic bliss.
