So what exactly are you asking me?The camber is about -1.8 negative in front. It's the stock suspension with Camber pins removed
I don't know if I've ever recommended -1.8° or any amount of toe out on the car, not sure why you ended up running this set up.Do you still recommend zero to on stock suspension with pins out -1.8 negative camber in front, or a touch of toe out, and is 1.5mm toe in on rear too much? I understand with more than -2 negative camber, everything should be closer to zero all the way around.
